Gerrelt
Re: Tiny Core Linux
Sun Jan 13, 2013 9:31 pm
Thank you bmarkus! I will check out the raspberry forum on tinycorelinux.
my Raspberry Pi page: http://raspberry.gerrelt.nl
bmarkus
Re: Tiny Core Linux
Mon Jan 14, 2013 11:58 am
Updated wpa_supplicant.tcz, missing drivers added. Try and let us know the result at http://forum.tinycorelinux.net/index.ph ... 491.0.html
bmarkus
Re: Tiny Core Linux
Mon Jan 14, 2013 7:31 pm
New piCore-X beta image available. It is compatible with both the 256M and 512M RAM boards:
http://www.hasix.org/tc/piCore-X-beta130114a.img.xz
bmarkus
Re: Tiny Core Linux
Wed Jan 16, 2013 11:21 pm
New version of piCore-X available:
http://www.hasix.org/tc/piCore-X-beta130116a.img.gz
flwm_topside.tcz updated to be compatible with WM/DE extensions.
bmarkus
Re: Tiny Core Linux
Fri Jan 25, 2013 9:01 pm
piCore updated to 4.7.4 base.
Visit Tiny Core Linux download page to get it:
http://tinycorelinux.net/ports.html
There is a new piCore-X image with 4.7.4 base, preinstalled graphical environment is unchanged. Download link:
http://www.tinycorelinux.net/4.x/armv6/ ... 24a.img.gz
Gerrelt
Re: Tiny Core Linux
Sun Jan 27, 2013 7:42 pm
Thanx bmarkus, I've just installed 4.7.4 and it works great! 8-)
Greetings,
Gerrelt.
bmarkus
Re: Tiny Core Linux
Tue Jan 29, 2013 11:44 am
New image, piCore-X-beta130129a is available. Changes:
- Xorg-7.6.tcz updated, keyboard issues fixed
Download link:
http://www.tinycorelinux.net/4.x/armv6/ ... 29a.img.gz
bmarkus
Re: Tiny Core Linux
Wed Feb 27, 2013 8:11 am
piCore updated to 4.7.5 base. See announcement and download info
http://forum.tinycorelinux.net/index.ph ... l#msg85237
piCore-X beta is also updated, see
http://forum.tinycorelinux.net/index.ph ... l#msg85295
bmarkus
Re: Tiny Core Linux
Sun Mar 24, 2013 3:49 pm
New piCore image dated 20130324 is now posted. It is a bug fix release adding missing gconv libs.
For download see: http://tinycorelinux.net/4.x/armv6/
Direct download: http://tinycorelinux.net/4.x/armv6/piCo ... 324.img.gz
Picore-X also updated. Direct download: http://tinycorelinux.net/4.x/armv6/piCo ... 324.img.gz
For more info visit http://forum.tinycorelinux.net/index.ph ... ,57.0.html
bricolodu13
Re: Tiny Core Linux
Sun Apr 21, 2013 12:03 pm
Following the Squeezelite post on Tiny Core, i would like to do the same "manually" to undestand what am I doing and do the same with GMediaRender.
My first problem is when I want to get Dropbear, I always get an error file "doesn't exist"
At the command promt
tce
s search
d Dropbear - choose the correct [16]
[16] Enter
----> wget: server returned error: HTTP/1.1 404 not found (tags.db.dropbear.tcz.info' : No such file or directory)
any idea ?
best regards,
Jean
Forrrge
Re: Tiny Core Linux
Thu Nov 07, 2013 8:27 am
This is looking good, anyone hear running it, thoughts on speed and performance ?
Looks as if its getting updated regular
Gerrelt
Re: Tiny Core Linux
Fri Nov 08, 2013 8:13 pm
I am still using Tinycore, now running piCore 5.0alpha6 on 3 Raspberries wireless as portable Squeezebox players.
Performance and speed is great. But I cannot judge on that, the player I use is very light (Squeezelite) and doesn't put much load on the system.
Franxois
Re: Tiny Core Linux
Thu Nov 21, 2013 12:08 pm
I think piCore is great and should have more visiblility.
I just try to unmount and remove the sdcard and the raspberry is still running. Is there other OS who allow that ??
Re: Tiny Core Linux
Thu Nov 21, 2013 12:27 pm
Franxois wrote:I think piCore is great and should have more visiblility.
Yes, you can hot swap the SD card in Raspbian *I think*.
jackokring
Contact: ICQ
Re: Tiny Core Linux
Thu Nov 21, 2013 4:04 pm
Nice work! Now if only I could load up my eeepc driver for wifi to work with the working wpa_supplicant. ;)
I think this distro is a nice compromise for custom software with small image downloads. It does have problems at present.
1) No wifi browser to find help by default.
2) No easy library for bit mapping a graphic array, and sound array.
3) A session use manager for say coding and gaming profiles, etc.
4) A tgz package builder.
Good points include
1) Session based commit to disk.
2) Low overheads on machine resources.
3) Fewer long term problems with static data.
2)
Pi[NFA]=B256R0USB CL4SD8GB Raspbian Stock.
Pi[Work]=A+256 CL4SD8GB Raspbian Stock.
My favourite constant 1.65056745028
visionimpaired
Re: Tiny Core Linux
Sat May 24, 2014 10:27 pm
I am trying Tiny Core and my pi does no automount or umount my USB memory stick (like hotswap).
Is there a trick to do to make this work?
Otherwise, I love the size - and the learning curve.
VI
Gerrelt
Re: Tiny Core Linux
Sun May 25, 2014 10:03 am
I didn't know how to either, but I think I figured it out now.
Most of this is taken from this post from bmarkus from the tinycore forum:
http://forum.tinycorelinux.net/index.ph ... l#msg52676
Login to piCore, and open this file:
(if nano not installed, execute first: tce-load -wi nano.tcz)
sudo nano /etc/udev/rules.d/98-tc.rules
Change the "Add" and "Remove" lines so the file looks like this:
KERNEL=="ram*", SUBSYSTEM=="block", GOTO="tc.rules_end"
KERNEL=="loop*", SUBSYSTEM=="block", GOTO="tc.rules_end"
ACTION=="add",          SUBSYSTEM=="block",     RUN+="/bin/sh -c '/usr/local/sbin/usbadd.sh %k'"
ACTION=="remove",       SUBSYSTEM=="block",     RUN+="/bin/sh -c '/usr/local/sbin/usbremove.sh %k'"
LABEL="tc.rules_end"
It now will call the shell scripts "usbadd.sh" and "usbremove.sh".
After editing, reload the rules:
sudo udevadm control --reload-rules
You will have to create the two scripts as follows:
sudo nano /usr/local/sbin/usbadd.sh
And add this to the file:
#!/bin/sh
rebuildfstab
sleep 3
mount /dev/$1 /mnt/$1
The next usbremove script:
sudo nano /usr/local/sbin/usbremove.sh
Add this:
#!/bin/sh
umount /mnt/$1
sleep 1
rmdir /mnt/$1
rebuildfstab
Now make the scripts executable:
sudo chmod a+x /usr/local/sbin/usbadd.sh
sudo chmod a+x /usr/local/sbin/usbremove.sh
Now you will have to make the changes and file persistent, open this file:
sudo nano /opt/.filetool.lst
And add these lines to the end of it:
And save it all:
filetool.sh -b
Do a reboot.
If you now plug in a USB drive, it should be automatically loaded.
It will take a few seconds, but then the files should be available under: /mnt/sda1
BE AWARE: This will not mount the drive at startup!! Only if you plug it in after startup.
bmarkus
Re: Tiny Core Linux
Mon May 26, 2014 7:35 am
The cleanest way is what Gerrelt posted, using custom udev rule for automounting. For unmounting no real good solution if user removes the stick without explicitely unmounting it, a script can't protect against data loss.
Return to “Other”
