tuxy
64bit Debian OS for Raspberry Pi 2
Sun Jan 14, 2018 3:41 pm
Is it possible install a 64-bit OS (like Pi64) on a RPi2?
jahboater
Re: 64bit Debian OS for Raspberry Pi 2
Sun Jan 14, 2018 3:43 pm
It might be possible on the new Pi2 which uses the same ARMv8 soc as the Pi3.
Sun Jan 14, 2018 4:40 pm
If you have RPi 2B version 1.2 BCM2837 SoC, try:
https://github.com/bamarni/pi64/blob/master/README.md
adieu
My other Computer is an Asus CS10 ChromeBit
tuxy
Sun Jan 14, 2018 5:24 pm
Hi, thank you for the answers.
I know it's a 2 but witch model, i don't know.
How can i see this model nr?
Sun Jan 14, 2018 5:32 pm
Post the results from the following commands
cat /sys/firmware/devicetree/base/model
and
cat /proc/cpuinfo
tuxy
Sun Jan 14, 2018 11:25 pm
Here the results:
Raspberry Pi 2 Model B Rev 1.1
processor : 0
model name : ARMv7 Processor rev 5 (v7l)
BogoMIPS : 57.60
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
processor : 1
BogoMIPS : 57.60
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
processor : 2
BogoMIPS : 57.60
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
processor : 3
BogoMIPS : 57.60
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
Hardware : BCM2835
Revision : a01041
Serial : 00000000d5ea8903
So, if i see, it is not possible with this RPi2 :-(
Mon Jan 15, 2018 1:03 am
It's not possible with that RPi2 V1.1
tuxy
Mon Jan 15, 2018 8:51 am
Ok, thanks.
Buying a RasberryPi2 Pi 3 :-)
2bdkid
Mon Mar 26, 2018 3:48 am
Debian has a arm64 installer image but I have not used it yet. I am working on creating a 64bit release of Debian through debootstrap similar to pi64 but hopefully with a better build script. The kernel gets stuck halfway through boot right but I'm making progress
boomonster
Wed May 16, 2018 1:12 am
The RPi 2 is 32-bit, so I don't see why you would want to
run a 64-bit OS on it... But If I knew an OS like that, I
would tell you. I think the RPi 3 is still running a 32-bit
OS! :lol:
Wed May 16, 2018 5:52 am
OS! :lol:
There are 2 versions of the RPi 2B, the initial release was ARMv7 BCM2836, whilst version 1.2 is ARMv8 BCM2837.
Raspbian Operating System is a re-spin of ARM32 Debian ARMHF which functions on all RPis, ARMv6 / ARMv7 / ARMv8 CPU Architecture.
There are many scenarios where running a 64bit Operating System is advantageous, and searching this Forum would find many Posts.
FYI the OP has an ARMv7 RPi 2B ;)
adieu
boomonster
Mon Jun 25, 2018 8:33 pm
I didn't know that. I looked it up but only saw
the 32-bit part.
Return to “Other”
