SusKahl
Berryboot VNC wpa_supplicant.conf disappears after activation of VNC in Debian for Raspberry
Thu Jan 11, 2018 8:39 am
Hi
I have folloved this guide for headless intallation of Berryboot (using wifi) http://www.berryterminal.com/doku.php/b ... stallation
It works fine undtil I install Debian for Raspberry boot and reboot. Then the wpa_supplicant.conf file disappears on the boot section. If I manually add the file once again and put the SD card back in the Raspberry pi the berryboot works fine undtil I use Debian once again.
on the screen connected to the PI (running headless) it says:
Succesfully Initialized wpa_supplicant.conf
Failed to open config file '/boot/wpa_supplicant.conf', error: No such file or directory
Failed to read or parse configuration '/boot/wpa_supplicant.conf '.
What am I doing wrong?
Return to “Other”
Who is online
Users browsing this forum: No registered users and 2 guests
