RayConcordNH
Ubuntu-Mate 16.04.2 Updates
Tue Mar 21, 2017 12:55 pm
If you have tried to update Ubuntu-mate 16.04.2 and get an error saying you need more space in the /boot partition, I have a work around video:
https://youtu.be/oYAnmjT8P-E
Re: Ubuntu-Mate 16.04.2 Updates
Tue Mar 21, 2017 3:54 pm
RayConcordNH wrote:If you have tried to update Ubuntu-mate 16.04.2 and get an error saying you need more space in the /boot partition, I have a work around video:
https://www.youtube.com/edit?o=U&video_id=oYAnmjT8P-E
Ubuntu-Mate, did you expand the file system ?
https://ubuntu-mate.org/raspberry-pi
Adieu
ktb
Tue Mar 21, 2017 7:33 pm
@fruitoftheloom - How would expanding the root file system help with a boot partition being too small?
@RayConcordNH - You should fix the link you posted to be the public URL for viewing the video. You posted a link used for editing the video post you made.
Tue Mar 21, 2017 9:53 pm
As the video is not viewable, was making sure he had setup Ubuntu-Mate correctly.
Maybe I should of stated to go the the developers forum ??
Adieu
Tue Mar 21, 2017 11:19 pm
Video works at: https://youtu.be/oYAnmjT8P-E (I didn't bother watching it - because I have better things to do for 19 mins.)
Note:The use of baseball bats for educational purposes is completely disallowed on this forum.
RayConcordNH
Wed Mar 22, 2017 1:54 am
If you watch the video you will see that the file system was already expanded, Ubuntu-mate does this automatically. I copy the contents of the PI_BOOT partition to a file on another drive. I then delete the PI_BOOT partition, shrink the PI_ROOT partition, and create a new larger PI_BOOT partition. I then copy the files back into the PI_BOOT partition. I walk through this completely assuming a newbie who has never used gparted. Use what you like and leave the rest.
Thanks DougieLawson for posting the correct link for the video, my mistake. I have corrected the link on the initial posting.
torak666
Tue Feb 06, 2018 5:02 pm
The video is a good example but not with a windows software so, just for information, i proceed the partition resize on windows 10 by using the software Partition Guru, it can't be possible with EaseUS Partition.
chymdangsun
Fri Feb 23, 2018 8:09 am
Hello , can i install LAMP on Ubuntu ? I want to run website on this :shock:
Fri Feb 23, 2018 12:53 pm
Please start a new thread rather than hijacking this one. Although the answer is almost certainly yes.
But I'd use Raspbian anyway.
Please direct all questions to the forum, I do not do support via PM.
Return to “Other”
