Kali linux on a Raspberry pi 2
Posted: Wed Mar 08, 2017 7:20 am
recently I've been trying to get my adafruit 2.8 inch touchscreen to work with Kali Linux 2.1.2 for the raspberry pi 2.
Unfortunately i ran into a confusing couple of errors,
the Pi boots normally and the screen runs through several lines of start up commands but stops at emergency mode.
Personally i don't know why this is as it only started after two boots of the pi normally (with the adafruit kernel installed).
However to run in default mode it says to type Control D.
Afterwards it runs through more setup until it stops at an error with the line:
Without touching it it proceeds to a command line login with the lines:
i perform the login for the root account and again it stops on after testing the wlan input, after searching online i found i could start the GUI manually with
but attempting this only leads to an error in:
I used several guides online such as starting
deleting the file
Furthermore i have tried all suggestions on this link:
http://www.linuxquestions.org/questions ... 175495810/
Again this is on kali linux any help would be well recieved.
Sincerely Koronter
failed to start ... root device.
see 'systemctl stat...ice' for more detail.Code: Select all
Kali GNU/Linux Rolling kali ttylCode: Select all
startxCode: Select all
mktemp: failed to create file via template '/tmp/serverauth.XXXXXXXXXX' : Read-only file systemCode: Select all
xauth: error in locking authority fileCode: Select all
xauth: timeout in locking authority file /root/.authority Code: Select all
Startxfce4Code: Select all
/tmp/.tX0-lockhttp://www.linuxquestions.org/questions ... 175495810/
Sincerely Koronter
