Parrot OS
Posted: Thu Jun 09, 2016 10:31 pm
by Stutter
Just put parrot on my pi 3 mod b. Small issue. When I use the parrot root password it doesn't accept it. So my question is do I have to use raspberry root password to access root an Sudo commands on my OS that I loaded onto my pi
Re: Parrot OS
Posted: Thu Jun 09, 2016 10:46 pm
by SonOfAMotherlessGoat
If it's another cheesy scriptkiddie leet hacker OS, have you tried the usual root/toor user/pass combo?
Re: Parrot OS
Posted: Fri Jun 10, 2016 2:09 am
by Stutter
Yes and it doesn't work.
Re: Parrot OS
Posted: Fri Jun 10, 2016 6:50 am
by B.Goode
Can't help but smile at the irony of installing a distribution targeted at Penetration Testing and being unable to find the root password....
Your favourite internet search tool will probably return lots of hits suggesting that @soamg is correct.
It is unlikely that the credentials will be specific to the RPi build, so perhaps explore https://www.parrotsec.org and seek assistance there?
Re: Parrot OS
Posted: Fri Jun 10, 2016 8:02 am
by fruitoftheloom
Stutter wrote:Just put parrot on my pi 3 mod b. Small issue. When I use the parrot root password it doesn't accept it. So my question is do I have to use raspberry root password to access root an Sudo commands on my OS that I loaded onto my pi
Where did you download the .IMG file from ??????????????
Re: Parrot OS
Posted: Sun Jun 26, 2016 12:11 pm
by akahbc
log in as user parrot password parrot.
Then on the top of the screen is a root terminal. click that
Then use the passwd command to change the password.
:D
Re: Parrot OS
Posted: Mon May 29, 2017 7:28 pm
by rithwik
┌─[[email protected]]─[~]
└──╼ $sudo passwd root
Enter new UNIX password: blahblah
Retype new UNIX password: blahblah
passwd: password updated successfully
Re: Parrot OS
Posted: Tue Mar 13, 2018 7:34 pm
by Sam31337
rpi3 with Parrot-rpi-2017.11.15_armhf.img just worked with password of toor . so default username was parrot and I just typed in toor as password. it worked. then pull up terminal and type passwd and enter the password of your choice.
Re: Parrot OS
Posted: Fri Aug 02, 2019 8:44 pm
by MidnightHacker537
The username is "parrot" and password is "toor". This should work! ;)
Re: Parrot OS
Posted: Fri Aug 02, 2019 9:26 pm
by Andyroo
Welcome to the forum
Shame your post is a year late :roll: :mrgreen:
Please check the dates of posts and if the OP has ever been back (just click their name to see last date here).
Mods normally lock threads like this and class them as zombies.
Worry not, the record is over 6 years late :lol: :lol: :lol:
