fredaunger
Boot Berryboot
Sun Jul 26, 2015 2:29 pm
Can any one help I have downloaded Berryboot Pi2 followed the instructions to load the sd card But when the card is in he Pi 2 all i get on the screen is repeating NO HDMI im using version of berryboot 201504-pi2-only. Any help woul be appreciated
Fred Aunger
nickthefish
Re: Boot Berryboot
Mon Jul 27, 2015 1:46 am
Fred,
I just overcame the exact same issue a few minutes ago by editing the config.txt file (on the BerryBoot installer on the SD card) to include the following line:
hdmi_force_hotplug=1
As found here: http://elinux.org/RPiconfig
You could also try:
hdmi_safe=1
Hope that helps.
fredaunger
Re: Boot Berryboot
Mon Jul 27, 2015 10:30 am
Hi. Thanks for the reply I have added the commands into config.txt but the result is the same.
disable_overscan=1
start_x=1
gpu_mem=128
# Berryboot settings, do not change
initramfs berryboot.img
[pi2]
kernel=kernel_rpi2_aufs.img
[pi1]
kernel=kernel_rpi_aufs.img
cma_lwm=16
cma_hwm=32
cma_offline_start=16
hdmi_force_hotplug=1hdmi_safe=1
fredaunger
Re: Boot Berryboot
Mon Jul 27, 2015 10:33 am
Hi. Sorry the above info is a copy of the config.txt file I wonder could you check it for me
Regards
Fred
fredaunger
Re: Boot Berryboot
Mon Jul 27, 2015 2:20 pm
Hi, After further investigation the config file is ok the pi boots into comp vid. I have connected a comp vid monitor and successfully installed berry boot. I have gone into /boot/config.txt and added hdmi_force_hotplug=1 and hdmi_drive=2 Do a reboot and it works with hdmi. But closing down killing the power and rpowering up it boots back into comp vid any clues
Fred
nickthefish
Re: Boot Berryboot
Tue Jul 28, 2015 7:25 am
Unfortunately, my knowledge is very limited so am unsure what else to suggest aside from trying a few other configurations in config.txt
I hope someone else can provide you with more help, and that you are able to resolve the problem.
Cheers
fredaunger
Re: Boot Berryboot
Tue Jul 28, 2015 7:43 am
Hi, Thanks for the info you have supplied it is appreciated I will continue with this little problem until its resolved.
Regards
Fred
Return to “Other”
