Page 1 of 2
Ubuntu 15.04 / Mate for Raspberry Pi 2
Posted: Sun Apr 26, 2015 3:56 am
by kim_lombard
Just got Ubuntu Mate (15.04) .img loaded and after some fine tuning. It runs great.
Just follow the instructions for downloading and installing the image (.img).
You don't need to do the build I just used the image.
https://ubuntu-mate.org/raspberry-pi/
after configuring I set up config.txt with this (yes I have heat sinks installed):
arm_freq=900
core_freq=450
sdram_freq=450
over_voltage=6
and I also found that using the MPEG-2 and VC-1 license keys by purchasing them from the Pi Store really helps with the screen redraw speed.
All in all, I'm impressed.
Total time to get it all running a couple of hours.
I have found a wealth of information on this forum, and just wanted to pass this along.
Re: Ubuntu 15.04 / Mate for Raspberry Pi 2
Posted: Sun Apr 26, 2015 12:09 pm
by fruitoftheloom
Yes I posted that 15.04 stable was released in the Original Thread
viewtopic.php?f=56&t=105345#p745234
Posted: Tue Apr 28, 2015 4:28 pm
by douggack
I'm also runnint Ubuntu Mate, and notice a peculial issue: I have System Monitor running, and it indicates that I am continuously receiving network data. Not sending anything, just receiving. It has been running for a little over 24.5 hours continuously, and has received 36.0 MiB. Anyone have a clue?
Doug
Posted: Mon May 04, 2015 12:28 pm
by cert
great image, i'ts running faster than ubuntu 14.04 linearo image. monitor suspend does not work. I'm trying to run mame/ mess, but it is very slow, i can't even choose anything in the menu to run a game.
Posted: Thu May 07, 2015 12:59 am
by LJH08
I have also just got mate running on raspberry pi 2 that I just bought locally. Its a good step up from my old revision 2 B board. This kind of what I consider "full" linux os on such a small, relatively cheap board is amazing...
However it seems it's using between 30-50 percent on each core simply idling with just the system operations running. (it favors core 1,2,3 over 4...) (Its a fresh install with only 2 custom programs installed and neither are running)
Any Idea if this is normal ?
Running default install at forced 1280x720p and oversampled to fill my 1080p monitor.
Posted: Thu May 07, 2015 4:41 am
by ktb
LJH08 wrote:However it seems it's using between 30-50 percent on each core simply idling with just the system operations running. (it favors core 1,2,3 over 4...) (Its a fresh install with only 2 custom programs installed and neither are running)
No, that doesn't sound normal at all. I didn't experience anything like that when I was playing around with it for a few days. I don't have it installed on any cards at the moment.
Posted: Thu May 07, 2015 9:11 pm
by LJH08
I seem to have it down to around 0-15 percent most of the time now. Not sure what was up. Running just system monitor jumps to 14-20.
Posted: Fri May 08, 2015 3:27 am
by Horrorzilla
I tried this distro 4 days ago and wasn't impressed, but just loaded it again since being added to NOOBS and it rocks. I have only been using it for a few hours but it is faster and more desktop alternative friendly than Raspbian in my opinion. I have been using Ubuntu flavors (mainly Xubuntu) for the last 7 years so this isfamiliar, user friendly, and fast. Thanks for the great work :D
Posted: Fri May 08, 2015 3:41 am
by Horrorzilla
*is familiar - sorry for the bad typing skills (I am anal about spelling and punctuation).
Posted: Sun May 10, 2015 2:33 am
by Mequa
How about adding this to BerryBoot?
That would have several advantages over NOOBS, namely the ability to share a partition with Raspbian and OpenELEC will all the space available to all OS's.
Also, I know this is Ubuntu MATE, but it would be nice to be able to run it with LXDE as well particularly with the enhancements found in Raspbian...
Posted: Sun May 10, 2015 2:39 am
by Mequa
I've had similar problems before on the Pi 2 running Raspbian on an inadequate power supply with power-hungry USB peripherals. For some reason that would max out an ARM core (just one, to 25%). See if upgrading to a 2A power supply fixes any such issues.
Posted: Sun May 10, 2015 8:21 pm
by Gary Littlemore
I'm trying to run tvcatchup.com via Firefox, but when I choose my TV channel it says: "Error loading player, No playable sources found."
Can anyone help on how to get the stream working?
Posted: Thu May 14, 2015 1:08 am
by LJH08
I don't think thats it since I only had a wifi and unifying logitech receiver connected, but if i can find a better PSU i'll try it out. Thanks for the suggestion.
Posted: Sun May 17, 2015 8:45 am
by apandada1
Horrorzilla wrote:I tried this distro 4 days ago and wasn't impressed, but just loaded it again since being added to NOOBS and it rocks. I have only been using it for a few hours but it is faster and more desktop alternative friendly than Raspbian in my opinion. I have been using Ubuntu flavors (mainly Xubuntu) for the last 7 years so this isfamiliar, user friendly, and fast. Thanks for the great work :D
Has Ubuntu Mate been added to NOOBS? I cannot see it.
Posted: Sun May 17, 2015 8:55 am
by DougieLawson
If you're a user with enough expertise to use Ubuntu Mate you do NOT need NOOBS. Take a look whether it's included with Berryboot if you really need a multi-boot manager (rather than the more simple option of sdcard swapping).
Posted: Sun May 17, 2015 11:36 pm
by Horrorzilla
Sorry - I meant to say since it was added to the Raspberry Pi download page.
Posted: Sun May 17, 2015 11:59 pm
by DougieLawson
Horrorzilla wrote:Sorry - I meant to say since it was added to the Raspberry Pi download page.
It's on https://www.raspberrypi.org/downloads/ if you scroll down that page.
Posted: Sat Jun 20, 2015 9:34 am
by nabilh2020
Using a HDMI eGalaxTouch type touch screen with natural resolution 1280X600
I have set up a ubuntu distro Ubuntu/Linaro, it is OK.
With the Mint 15.04, I have a problem with GUI not filling the whole screen.
It does fill the whole screen without doing anything else with Raspbian, OpenElec, and Ubuntu/Linaro,
but with Mint 15.04, there are huge black borders around the screen.
I tried to change the file config.txt, but all it did was change resolution inside the same size screen
with same black borders.
Can you advise how to make it expand to the whole screen as it does for other distros?
If anyone knows please contact me on G+ or email me: [email protected]
Posted: Fri Jul 24, 2015 10:58 pm
by avoura
I just installed Ubuntu Mate from the image I downloaded onto a Raspberry Pi 2. Mostly it seems okay, but sometimes a bit slow, including in Firefox, but it is pretty awful in YouTube, or when playing an audio file in Audacious, Rhythmbox or VLC. It plays very stuttery in the audio apps, and there is no sound at all in VLC. I already added my user account to the Audio group, so it should play audio okay, but it's not good. I also own a Raspberry Pi B on which I run OpenElec, connected to my TV via HDMI. It plays music and videos perfectly, never had a problem, yet the new R Pi has more RAM, more CPU but cannot cope with music in Ubuntu Mate.
So what is going on and why these problems? I am using an 8 GB Micro SD card (partition resized to fill the card), no other USB drives at present, using a USB keyboard and mouse, and audio is coming via the HDMI plugged into monitor which has a headphone socket into which I have plugged headphones.
Posted: Sat Jul 25, 2015 9:29 am
by avoura
Update on previous post:
I installed gstreamer mp3 codec from software centre and it made no difference to mp3.
Then I installed ogg converter and converted an mp3 file to ogg and then the ogg file played perfectly.
So what are the difficulties with playing mp3 caused by?
Posted: Mon Jul 27, 2015 3:34 am
by Art_PI2
avoura wrote:Update on previous post:
The thing is mpg123
./configure --with-cpu=arm_fpu --with-default-audio=alsa
Potential problems:
export LD_LIBRARY_PATH=/usr/lib:/usr/lib/mpg123
export LD_LIBRARY_PATH=/usr/lib:/usr/local/lib/mpg123
This I did on my Cubieboard.
Posted: Mon Jul 27, 2015 9:25 pm
by avoura
I have no idea what all that means.
Art_PI2 wrote:
The thing is mpg123
Potential problems:
Posted: Thu Jul 30, 2015 11:06 am
by avoura
I have not changed anything, but now my Pi is having difficulties playing ogg files as well, even though it played them perfectly a few days ago.
Posted: Thu Oct 15, 2015 8:09 pm
by PokeEngineer
Can you install Steam on Ubuntu for Raspberry Pi 2?
:idea:
Posted: Thu Oct 15, 2015 9:02 pm
by fruitoftheloom
RetroNerd wrote:Can you install Steam on Ubuntu for Raspberry Pi 2?
:idea:
Both SteamOS & Steam Linux Client require a machine with x86 CPU Architecture ;)
