Windows CE for the Pi 2
Posted: Sat Mar 14, 2015 9:41 pm
by Sandy Bridge
Hello.
Since the development of Windows CE 7 for the original Pi has been abandoned due to the lack of support for the USB controller, I thought that we develop it for the Pi 2. It has a new SoC, newer architecture, and will support Windows 10. Here's the thread for the original BSP. http://www.raspberrypi.org/forums/viewt ... 56&t=58259
Re: Windows CE for the Pi 2
Posted: Sat Mar 14, 2015 10:33 pm
by xoopha
And the USB controller is the same, isn't it?
Posted: Sat Mar 14, 2015 10:42 pm
by Sandy Bridge
xoopha wrote:And the USB controller is the same, isn't it?
I'm not sure. I haven't found a data sheet for the BCM2386 yet. But if it is, then, well.... Guess I should move to x86 then.
Posted: Sat Mar 14, 2015 11:12 pm
by fruitoftheloom
Yes in very basic terms only the CPU & Memory have changed on the RPi2 B
Regards RPi Windows 10 that is for IoT, just like Intel Galileo device.
Posted: Sat Mar 14, 2015 11:13 pm
by mahjongg
Yes, except for the CPU core and memory everything on a 2B is the same as a B+, (except for an extra hardware counter on the B2, that can be used by a new USB stack to improve it's performance).
Forget about Windows CE on a PI, its a closed subject. as is this post, enough is enough, I got another complaint about thread necro-ing....
