tounch
Re: Debian Jessie (codename Aliendeb) for Raspberry Pi 2
Thu Mar 12, 2015 11:58 am
With raspbian and chromium I ve got the same problem with the videos :(
gkreidl
Thu Mar 12, 2015 12:01 pm
tounch wrote:With raspbian and chromium I ve got the same problem with the videos :(
Chromium doesn't support hardware (GPU) acceleration for videos. Only browsers based on the new webkit3 engine can do this (epiphany, kweb3).
Minimal Kiosk Browser (kweb)
karl_k
Fri Mar 13, 2015 2:33 pm
Hi !
Got your image running, works fine!
Could you let us know where you got Kodi 14.1~jessie from ?
Did you compile yourself ? If yes, would you be so kind as to share your ./configure parameters and an outline of the procedure ?
Thanks,
Karl
geinux
Tue Mar 17, 2015 8:41 am
karl_k wrote:Hi !
Thanks,
Karl
install repository jessie:
terminal:
sudo apt-get install kodi
geinux
Fri Mar 20, 2015 2:59 pm
aliendeb-rpi2-20150320.img
***download torrent***
https://www.dropbox.com/s/wezl04n4xhlxq ... rrent?dl=1
***NEW*** :D :D :D :D :D :D :D
## by geinux 2015/03/20, new codename Aliendeb
## Updates
- Aliendeb Mod, boot/firmware/config.txt
- 32-bit color
- editing /etc/network/interfaces
- editing Debian testing /etc/apt/sources.list
- Kodi media center
- LibreOffice
- Chromium web browser
- PepperFlash 12.0.0.77
- Telegram, messaging web-app with a focus on speed and security, it’s super fast, simple and free.
- xfsprogs, Utilities to create, repair and administrate xfs-filesystems
- New theme abwaita
- Aliendeb app
**youtube**
https://www.youtube.com/watch?v=mkWYCPK ... e=youtu.be
**Torrent**
**Bittorrent Sync** - keep updated
https://link.getsync.com/#f=rpi-2&sz=68 ... HODVQLYRPD
PiPiper
Fri Mar 20, 2015 11:40 pm
Thanks for the update ... working great! loaded geany and gcc. No issues ... although I updated the hdmi settings in config.txt. Running on a RP 2.
-Doug
update: having some issues with Kodi both freezing on startup or black screen on exit. Sometimes it works ok ... there seems to be two instances of it in top and when you use kill it restarts on it's own. Will test it on another system later today. Error in log file is FATAL: Capplication::Create: Unable to create window with some errors before that; EGL error in CreateSurface: 300b and error CreateWindow: could not create surface and error CreateNewWindow: Could not create new window.
alberto
Mon Mar 23, 2015 6:49 pm
Same problem here: Kodi freezing on startup or black screen on exit...
Joe Schmoe
Mon Mar 23, 2015 9:48 pm
Does anyone know when this image will be hosted on a normal server, so that people (like me) don't have to mess around with torrent sh*t?
Alternatively, so I've downloaded this 21K ".torrent" file. What do I do with it?
geinux
Tue Mar 24, 2015 3:47 am
Joe Schmoe wrote:Does anyone know when this image will be hosted on a normal server, so that people (like me) don't have to mess around with torrent sh*t?
downloaded this 21K ".torrent" file :shock:
Please be patient you are downloading, possibly the server is busy as it uses bittorrent and btsync simultaneously
ktb
Tue Mar 24, 2015 3:54 am
I think he's asking what the next step after downloading the .torrent file would be. The answer is that you would open that .torrent file with a BitTorrent client such as uTorrent or Transmission which should begin to download the .img file you want.
Joe Schmoe
Wed Mar 25, 2015 3:58 am
I've got a "torrent client" called (amazingly!) "unworkable" that actually has worked well in the past.
However, it doesn't work on this image. I'm not particularly interested in endless mucking around with "torrent" clients.
Therefore, i ask again, is there any chance this will be hosted on a regular system at some point?
geinux
Wed Mar 25, 2015 6:34 am
Joe Schmoe wrote:I've got a "torrent client" called (amazingly!) "unworkable" that actually has worked well in the past.
Install transmission BitTorrent,
utorrent, Deluge in linux. :roll:
ktb
Wed Mar 25, 2015 8:02 am
I'll upload it somewhere for you temporarily if the OP doesn't mind.
Joe Schmoe
Wed Mar 25, 2015 10:40 pm
For what it is worth, whenever I try to get this image via torrent (unworkable), it "stalls".
I've tried this from at least 2 different (global) IP addresses.
See below:
% unworkable aliendeb-rpi2-20150320.zip.torrent
{At this point, it spins through a "hash check", and creates the 1G file shown below - which consists of all nulls - then just "stalls" until I hit ^C)
aliendeb-rpi2-20150320.zip.torrent hash ok: 0% rx: 0 0.0KB/s - stalled -^C
% ls -lsa
6328 -rw------- 1 user group 1,102,600,990 Mar 25 16:23 aliendeb-rpi2-20150320.zip
xoopha
Wed Mar 25, 2015 11:29 pm
The torrent definitely works. It doesn't download that fast, 150-200KB/s or so, but it works.
ktb
Thu Mar 26, 2015 12:10 am
Confirmed. I've downloaded aliendeb-rpi2-20150304.zip and aliendeb-rpi2-20150320.zip using Transmission.
Joe Schmoe
Thu Mar 26, 2015 1:08 am
Probably works in some parts of the world, but not in others...
geinux
Thu Mar 26, 2015 1:27 pm
** Windows BitTorrent Sync Installation and Configuration **
https://www.youtube.com/watch?v=feQdjDb1xCQ
**link Bittorrent Sync**
https://link.getsync.com/#f=rpi-2&sz=12 ... HODVQLYRPD
dom
Thu Mar 26, 2015 5:01 pm
PiPiper wrote:having some issues with Kodi both freezing on startup or black screen on exit. Sometimes it works ok ... there seems to be two instances of it in top and when you use kill it restarts on it's own. Will test it on another system later today. Error in log file is FATAL: Capplication::Create: Unable to create window with some errors before that; EGL error in CreateSurface: 300b and error CreateWindow: could not create surface and error CreateNewWindow: Could not create new window.
Most likely a lack of gpu memory. What do you have gpu_mem set to? Needs to be at least 128 (ideally 256).
Joe Schmoe
Fri Mar 27, 2015 1:04 pm
geinux wrote:***Aliendeb 20150320 direct download*** :D :D :D :D
https://drive.google.com/uc?export=down ... HkzUnJtRkU
This doesn't work for me. I need a simple download link that I can "wget".
If you're tempted to ask why this is so, don't. It's complicated.
BTW, the irony of one of the "I've got an image, guys!" guy hosting his image on a Microsoft server is not lost on many. Hosting one on a Google server is only slightly less ironic...
PiPiper
Fri Mar 27, 2015 4:58 pm
Thanks Dom for the suggestion ... the default from the aliendeb config file was 160 so I bumped that up to 256. Did not seem to make any difference. Top is showing 752352 total memory so it does look like the GPU is using the remainder. I've tried some searches and some more testing. It seems that if i start kodi from the terminal kodi -standalone then when I exit it stills goes to a black screen but then i can hit ctrl-alt f1 and alt-f7 to get the gui back. Adding the additional memory and making sure that I only click the icon once seems to have fixed the hanging up on Kodi startup issue (I was always seeing two instances of kodi in top in these cases from the ssh login)
- thanks again for any help or suggestions you might have.
Doug
alberto
Fri Mar 27, 2015 6:41 pm
The problem with KODI Persist also after changing gpumen to 320....
alponme
Sat Mar 28, 2015 6:22 pm
Why /boot/firmware/config.txt hace args gpu_mem and force_turbo repeated?
Return to “Other”
