sndwvs
slarm64 - unofficial aarch64 Slackware Linux port
Mon Jun 29, 2020 7:03 pm
support for slarm64 for raspberry pi 3/4 (aarch64 unofficial port slackware)
the system can be assembled as armhf and aarch64, assemblies are made under aarch64
links:
site: slarm64.org
forum: linuxquestions
downloads: raspberry pi 3
downloads: raspberry pi 4
development: https://gitlab.com/sndwvs/images_build_kit
shortly about the slarm64, a simple non-overloaded system for everyday and not just use.
https://www.patreon.com/slarm64 -> donation slarm64
gilius
Re: slarm64 - unofficial aarch64 Slackware Linux port
Sun Sep 27, 2020 12:41 am
How to install a video player on there to test it?
sndwvs
Sun Oct 04, 2020 5:48 pm
gilius wrote:How to install a video player on there to test it?
ffmpeg is already installed on the system.
to install mplayer you need in /etc/slackpkg/mirrors
uncomment one of the mirrors.
and execute the commands:
slackpkg update
slackpkg install MPlayer
sndwvs
Wed Dec 30, 2020 6:29 am
update
  • added boot model 400 and cm4
    fixed booting from usb
PI 400 howto:
after writing on the SD card, mount /dev/mmcblk0p1 and change to the uEnv.txt file replace the file name fdtfile=bcm2711-rpi-4-b.dtb with fdtfile=bcm2711-rpi-400.dtb
slarm64-current-aarch64-base-raspberry_pi_4-5.10.3-build-20201229.img.zst
slarm64-current-aarch64-base-raspberry_pi_4-5.10.3-build-20201229.img.zst.sha256
slarm64-current-aarch64-xfce-raspberry_pi_4-5.10.3-build-20201229.img.zst
slarm64-current-aarch64-xfce-raspberry_pi_4-5.10.3-build-20201229.img.zst.sha256
sndwvs
Tue Mar 16, 2021 5:13 pm
update 2 kernel 5.11.0
kernel 5.10.23
sndwvs
Sat May 01, 2021 8:34 pm
update kernel 5.12.0
thatchunkylad198966
Sun May 02, 2021 8:14 pm
Any chance of a .tar?
I had a lot of trouble extracting and gave up.
Cheers.
sndwvs
Wed May 05, 2021 5:42 pm
these are slackware packages (simple tar.xz archive) unpack
 tar xvf *.txz
thatchunkylad198966
Wed May 05, 2021 6:43 pm
 tar xvf *.txz
Must be me then.
Because I remember trying to extract it and Googling how to, getting it's something to do with a games console.
I'll try again, thank you. :)
Return to “Other”
