Stutter
Parrot OS
Thu Jun 09, 2016 10:31 pm
Just put parrot on my pi 3 mod b. Small issue. When I use the parrot root password it doesn't accept it. So my question is do I have to use raspberry root password to access root an Sudo commands on my OS that I loaded onto my pi
SonOfAMotherlessGoat
Re: Parrot OS
Thu Jun 09, 2016 10:46 pm
If it's another cheesy scriptkiddie leet hacker OS, have you tried the usual root/toor user/pass combo?
Account Inactive
Stutter
Re: Parrot OS
Fri Jun 10, 2016 2:09 am
Yes and it doesn't work.
B.Goode
Re: Parrot OS
Fri Jun 10, 2016 6:50 am
Can't help but smile at the irony of installing a distribution targeted at Penetration Testing and being unable to find the root password....
Your favourite internet search tool will probably return lots of hits suggesting that @soamg is correct.
It is unlikely that the credentials will be specific to the RPi build, so perhaps explore https://www.parrotsec.org and seek assistance there?
Re: Parrot OS
Fri Jun 10, 2016 8:02 am
Stutter wrote:Just put parrot on my pi 3 mod b. Small issue. When I use the parrot root password it doesn't accept it. So my question is do I have to use raspberry root password to access root an Sudo commands on my OS that I loaded onto my pi
Where did you download the .IMG file from ??????????????
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
akahbc
Re: Parrot OS
Sun Jun 26, 2016 12:11 pm
log in as user parrot password parrot.
Then on the top of the screen is a root terminal. click that
Then use the passwd command to change the password.
:D
rithwik
Re: Parrot OS
Mon May 29, 2017 7:28 pm
┌─[[email protected]]─[~]
└──╼ $sudo passwd root
Enter new UNIX password: blahblah
Retype new UNIX password: blahblah
passwd: password updated successfully
Sam31337
Re: Parrot OS
Tue Mar 13, 2018 7:34 pm
rpi3 with Parrot-rpi-2017.11.15_armhf.img just worked with password of toor . so default username was parrot and I just typed in toor as password. it worked. then pull up terminal and type passwd and enter the password of your choice.
Return to “Other”
