gravecad1
hard drive and risc os pi
Tue Aug 19, 2014 10:09 am
Hi
Could any one give me some instructions on how to use the hard disk
drive with RISC OS pi.
thanks.
r3d4
Re: hard drive and risc os pi
Tue Aug 19, 2014 11:35 pm
Real life is, to most, a long second-best, a perpetual compromise between the ideal and the possible.
Meanwhile, the sysadmin who accidentally nuked the data reckons "its best not run anything more with sudo today"
what about spike milligan?
gravecad1
Wed Aug 20, 2014 5:26 pm
Hi
Thanks for the reply.
How do you access the hard drive with riscos? Is it possible to send a app
to the hard disk?
svrsig
Thu Aug 21, 2014 3:34 pm
gravecad1 wrote:Hi
to the hard disk?
If you have a Raspberry Pi with the RISC OS RC12a SD card image on the SD card then you will see that application directories (those that begin with a '!') are included inside the directories 'Apps' and 'Diversions'. If you plug in a USB pen drive (for simplicity no larger than 2Gbytes) you will see another disc icon on the icon bar that is a SCSIFS drive. Click over it to open it and then you can simply drag and drop any apps you want to from the SDFS drive to the SCSIFS drive. Simples.
You can also use !Store to download any apps you want onto the hard disc and open the archive to put them where you want.
What you mean by 'the hard disc' is, of course, unclear - the SD card or the pen drive or a 'USB hard drive' plugged into a USB socket?
gravecad1
Thu Aug 28, 2014 5:11 pm
hi
thanks very much i have used the hdd successfully.
Return to “RISCOS”
