SEDev
StrongED 4.69 released
Sun Sep 01, 2013 11:42 pm
Hi, I'm pleased to announce that StrongED 4.69 is now available from
the StrongED website: http://www.stronged.iconbar.com/
Please note that this is a minimal release that contains only BaseMode.
Other modes that you may wish to use have to be downloaded separately
from the website (Download page -> Modes database).
There have been many of changes as well as a number of bug fixes.
Some of the changes made are listed below.
About StrongED
StrongED is a general purpose text, file and program editor for RISC
OS. Although StrongED is a very fully-featured and powerful editor, it
is also surprisingly easy to use.
It may be used for writing an HTML page, writing emails, or writing
text that you later propose to transfer to some other program such as
Ovation Pro, Techwriter.
Alternatively it can be used to write Obey files (OS command scripts),
Basic programs or source code in a variety of languages. It can also
be useful for looking at the contents of non-text files, to see if
there is anything meaningful!
List of changes
A lot of the work done for 4.69 has been behind the scenes stuff such
as moving blocks of code to their own source file (source now consists
of 32 files, from the original 17) and refactoring various bits of
code. As a result there aren't as many user facing changes as in
previous releases but there are still some worthwhile new features.
One important change is that StrongED is now ARMv7 compatible meaning
that it will run on all the new machines that are based on BeagleBoard,
PandaBoard and Raspberry Pi.
Another big change, support for outline fonts has been much improved.
Files with embedded control codes are now handled correctly, including
printing. There however still minor glitches when using outline fonts,
StrongED wasn't originally designed with outline fonts in mind.
The Goto dialogue box has been extended, it's now possible to go to a
physical line, a logical line or a file offset (address in Dump mode).
Searching in Dump mode now searches the raw binary when displayed as
Byte, Half, Word or ASCII. In Asm display the disassembly is searched.
The Half display type has been added; it displays a file as 16 bit
(half-word) values.
Advanced search has gained a few new search tokens:
  • <<< and >>> to match start and end of text respectively
  • << and >> to match the start or end of a paragraph
  • \{ and \( to match the current search position against the bracket and
    search forward trough the text to find the matching closing bracket.
    Nesting is taken into account, strings and comments are skipped.
    The search continues after the matching bracket.
The List-of-Windows now allows you to close texts. If a text has been
altered then it will be saved first. You can select the texts manually
or you can filter out texts based on status (changed/unchanged), path
and/or filetype.
Finally a few minor improvements: Added the option to make newlines
visible. Filetypes &AA5 (TskBasic) and &9FB (Basalt) are recognised as
containing Basic and detokenised on loading. List-of-Found & Throwback
windows can now be scrolled using the scrollwheel on RISC OS 5.
Return to “RISCOS”
Who is online
Users browsing this forum: No registered users and 2 guests
