Witzo
The Acorn Copy key: to which key is it mapped?
Mon Apr 01, 2013 9:08 pm
Reading the BBC Basic VI manual, I come across an explanation to edit a line of basic code. It requires the Copy key. Where is it mapped on everyday PC/Mac keyboards?
I'd like to change a line without needing to type it all over.
Of course I can do this in StrongED, but then I can't use the full 'MODE MODE' screen that I use for graphics and quickly test the result of my changes.
AMcS
Re: The Acorn Copy key: to which key is it mapped?
Mon Apr 01, 2013 10:10 pm
Witzo wrote:Reading the BBC Basic VI manual, I come across an explanation to edit a line of basic code. It requires the Copy key. Where is it mapped on everyday PC/Mac keyboards?
If the line is visible on screen (but above you're current empty line) just press the "up arrow" key (the cursor should now "separate" there's a flashing one and a "block" one. Move the upper cursor (with the "up arrow" key until you reach the line you wish to copy from - press the <END> key each time you want to copy a character (the character copied will appear on the lower line). (<END> on PC keyboards functions like "COPY" did - on a real BBC/RISC OS machine you'd actually have a key called "COPY").
When complete press the <ENTER> key.
Note if you're copying program lines you'll need to copy the line number as well as any text - you can "type" new characters on the current line and mix them with ones you've copied (pressing <END> each time you want to copy a character from the old line).
If you want to exit without changing anything hit <ESCAPE>
Hope that helps.
Witzo
Tue Apr 02, 2013 8:09 pm
That's what I was looking for, thanks!
The 'end' key on the Mac is the one that has an arrow pointing to the lower right.
My Basic editing has become noticeably faster. :)
AMcS
Tue Apr 02, 2013 9:49 pm
Witzo wrote:That's what I was looking for, thanks!
No problem - pleased to help !
Return to “RISCOS”
