Monitor output problems.
Posted: Mon Nov 19, 2012 10:12 am
by PhillHS
Hi all,
I've just setup my pi with the latest riscos image and all seems to be working correctly except that I am having problems with the video output.
I'm using the composite video output with a TV / monitor combo that's capable of displaying up to 1280x1024. No matter what monitor I select I have two problems :
Firstly the output in all but the lowest resolutions is a trifle blurred, this seems worse under the mouse cursor as it moves, I suspect this may be down to using the composite video and may go away, if i used the HDMI output....I have a HDMI to DVI cable on order.
Secondly even if I select a 4:3 resolution such as 1024x768 the image is displayed with black bars on the left and right hand side as if it where trying to display a 4:3 image on a widescreen monitor which mine is not, is this a known problem ?
Cheers.
Phill.
Re: Monitor output problems.
Posted: Mon Nov 19, 2012 2:13 pm
by bhtooefr
Try putting the following line in config.txt (but this should be a default):
sdtv_aspect=1
That will force it to treat the composite display as 4:3.
Also, I would recommend only using a max of 800x600 over composite - anything higher will be too blurry.
Posted: Tue Nov 20, 2012 1:54 pm
by PhillHS
bhtooefr wrote:Try putting the following line in config.txt (but this should be a default):
sdtv_aspect=1
That worked, though oddly, the mouse won't move up to the left and right edges of the screen, it seems to stop a couple of cm in from each side :(
Yep that's what I found.
Anyway hopefully my HDMI to DVI converter will arrive today which should fix the problem.
Cheers.
Phill.
Posted: Tue Nov 20, 2012 3:46 pm
by michele.x
sdtv_aspect=1
add also
sdtv_mode=2
and
into RiscOS select 640x512 resolution, or 640x480
Doing this only the scaler of the tv will upscale the signal.
