FreezeTile
RISC OS Composite Output?
Sun Nov 25, 2018 9:31 pm
Does anyone know how to get RISC OS to output video through the 3.5mm AV jack? I'd use a HDMI to AV converter, but I'm hoping to get all the cables into a relatively small case, so the less space used up the better. Thanks!
DavidS
Re: RISC OS Composite Output?
Sun Nov 25, 2018 9:49 pm
Simple, do not hook up HDMI at all.
Also check your config.txt, if it has the line:
hdmi_force_hotplug=1
remove that line, as that would make the Pi think that HDMI is plugged in.
RPi = The best ARM based RISC OS computer around
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers. Most of the rest from RISC OS on RPi 2B/3B/3B+ computers
FreezeTile
Sun Nov 25, 2018 10:13 pm
I've got it working now, thanks! :-D
Return to “RISCOS”
