Is it possible to install RISC OS on a Pi Zero?
Posted: Thu Jan 19, 2017 12:20 pm
by jubber
Hi there chaps - having a lot of trouble getting Risc OS to install on my raspberry pi zero. I tried using win32DiskImager and dropped the riscos-2015-02-17-RC14.img file on to it - the Pi Zero just remained a blank screen. Then I got NOOBS running (tested with a Raspbian OS that installed correctly) but RISC_OS directory wasn't recognised, even with lots of rename attempts. Then I tried an old version of NOOBS with all the OSes on it - RISC OS wasn't recognised. Finally I used a new version of NOOBS but with the old version's copy of RISC_OS and this time at least the bootloader did show RISC OS as an option. Unfortunately it then said Risc OS could not install - "size of recovery partition too large"? I have a bog standard 8gb SD card.
What's my next step? I've googled this problem for some time and must be using the wrong terms because getting the information is proving ... frustrating.
Is it even possible to install risc os to a Pi Zero?
Many Thanks
Re: Pi Zero
Posted: Thu Jan 19, 2017 1:20 pm
by ElEscalador
Maybe put that in the subject line and the people that know might answer...because "Pi Zero" is so vague no one cares.
Re: Pi Zero
by B.Goode
The PiZero was released towards the end of 2015.
No Operating System or Installer released prior to that date will boot up the PiZero without intervention or modification.
The NOOBS Installer, even the 'full' offline version, contains only the Raspbian Operating System. To be able to see other Operating Systems available for installation from online sources your RPi will need a working internet connection.
Re: Pi Zero
Posted: Thu Jan 19, 2017 3:11 pm
by jubber
Righto - subject line changed. Considering this is the RISC OS part of the forum I thought "Pi Zero" might have been sufficiently obvious - but your advice is well taken
Re: Pi Zero
Posted: Thu Jan 19, 2017 3:28 pm
by jubber
B.Goode wrote: tried using win32DiskImager and dropped the riscos-2015-02-17-RC14.img file on to it
Part of your reply is incorrect - NOOBS installer comes in a version which *does* contain multiple operating systems - although it does take a bit of searching to find it. Moreover the NOOBS installer has a folder called "os" - so even on the lite versions you can place various operating systems for offline install before the SD card is rejigged by the pi's boot system. However, if you're correct in saying that nothing made before late 2015 will install then presumably you are saying, definitively, that RISC OS cannot be installed on the Raspberry Pi Zero, because that img file was the latest one I could find on the RISC OS website.
That's a pity.
Moreover the Pi Zero does not have pre-boot wifi capabilities, so no method to install RISC OS exists (although there is one wifi module that works in the pre-boot mode, but it costs four times as much as the Pi Zero itself, making it rather an expensive experiment).
Re: Is it possible to install RISC OS on a Pi Zero?
Posted: Thu Jan 19, 2017 4:10 pm
by B.Goode
I'm always happy to learn something new. Where is that version of NOOBS documented and downloaded please?
Re: Pi Zero
Posted: Thu Jan 19, 2017 5:06 pm
by ElEscalador
Good point - I tend to forget that there are even different forums because I think a lot of us just fire up and hit "new posts" - which gives no indication of the individual forum anything is posted in unless you do some digging.
Posted: Thu Jan 19, 2017 5:45 pm
by jubber
It took a bit of digging on various forums but one or two posts linked to the following -
http://downloads.raspberrypi.org/NOOBS/ ... 014-07-08/
I'm not sure which posts lead me there - I'm very new to these forums - but it was being discussed as the last full fat version of Noobs (before it was shrunk for the benefit of 4GB cards?)
It contains various OS flavours, including RiscOS. Although this is old, the Pi Zero hardware is also, as far as I know, very similar to the model B. This NOOBS version did run, and Raspbian installed successfully from it - but RISC OS did not. It must be very nearly compatible - or possibly my Pi Zero is knackered in some subtle fashion.
Posted: Thu Jan 19, 2017 6:27 pm
by B.Goode
I am not going to retrospectively edit what I wrote as that would be confusing.
But I should have written:
The current release of the NOOBS Installer, even the 'full' offline version, contains only the Raspbian Operating System.
That has been the case for over two years.
Posted: Thu Jan 19, 2017 8:20 pm
by mikerr
There's a Pi Zero RiscOS image here:
https://www.riscosopen.org/forum/forums/1/topics/3858
http://riscos.openpandora.org/Projekte/ ... I_Zero.zip
Supported method is probably to run the latest NOOBS install on a network connected pi3 , select and install riscos then put the sd card in a Zero once finished....
Posted: Thu Jan 19, 2017 9:03 pm
by jubber
Ah - so it looks as if getting the pi zero to install RISC OS is not possible if you only have a pi zero.
Posted: Thu Jan 19, 2017 11:22 pm
by jubber
Mikerr - the second link you posted, which had a download for riscos-2016-01-03-RC14_DSI_Zero - actually worked!
Many thanks - that's the nth file I've tried and the first that did anything. Hopefully any other Pi Zero owners who struggle to find the right information will eventually find this topic and have more success than I initially did.
Cheers,
Robin.
Posted: Tue May 23, 2017 2:16 pm
by madtom1999
Does the wifi work with it?
Posted: Tue May 23, 2017 2:54 pm
by fruitoftheloom
madtom1999 wrote:Does the wifi work with it?
RC15 has been released recently:
https://www.riscosopen.org/content/down ... spberry-pi
Maybe ask the developers of this OS ??
Posted: Wed May 24, 2017 5:34 am
by dfeugey
No.
Posted: Fri Jun 09, 2017 9:40 pm
by Shawty
Iv'e just tried R15 as I read this. Stock SD w/RiscOS wont boot on Pi0 but boots fine on original Pi
Posted: Fri Jun 09, 2017 10:19 pm
by fruitoftheloom
Best to ask the RiscOS Developers ???
Posted: Wed Jun 28, 2017 4:12 pm
by Grumpy Mike
I tried that and riscos does not come up as an option.
Can you be a bit more specific as to where / or how you put in the RiscOS image. I have downloaded it but can't seem to find a way to include it.
Posted: Wed Jun 28, 2017 4:41 pm
by fruitoftheloom
""RC15 SD card image 2017-04-20 12:58:52"" a SD Card needs to be created from this .IMG file, software like Etcher can handle this:
https://etcher.io/
If you want to use NoobS, may I suggest you use PINN instead:
viewtopic.php?f=63&t=142574&p=1168249#p1168249
Posted: Wed Jun 28, 2017 6:11 pm
by Grumpy Mike
Thanks a lot Etcher worked a treat.
Cheers
