scruss
Re: Readable Code Style, Review Requested.
Wed Nov 23, 2016 6:14 pm
Yes, NetSurf (which I'm currently posting from) does not render <code> tags properly. Even explicitly setting
code { font-family: 'Andale Mono', monospace; }
in the browser's default.css doesn't fix it. This is in the latest version, freshly pulled from git.
It may be a fast, small browser (though it's hoovering up nearly a gigabyte of RAM on this x86_64 for one tab and seemingly no JavaScript, so it's not very efficient) but it's barely usable for most web pages.
DavidS
Wed Nov 23, 2016 11:28 pm
jahboater wrote:
DavidS wrote: as the fixed width font in NetSurf is not Fixed Width.
Then its not the forum at fault.
You just need to find a working browser.
You took that statement out of context. It may be that the fixed width in NetSurf is not fixed width.
Though I banged up a quick html with < code > < / code > tags around the same code and it was indeed fixed width, so the problem is NOT Netsurf.
26-Bit R15 to 32-bit. 16-bit addressing to 24-bit. ARM and 65xx two CPU's that continue on, and are better than ever. Assembly Language forever :) .
DavidS
Wed Nov 23, 2016 11:32 pm
scruss wrote:Yes, NetSurf (which I'm currently posting from) does not render <code> tags properly. Even explicitly setting
WOW, a gig of RAM in Netsurf???????
I have never seen Netsurf go past 32MB of ram total (less than 8MB for its WinpSlot and up to about 24MB for its allocated dynamic blocks). Though as NetSurf was made for RISC OS, I have never used it on any other system (Ok I use it on Atari TOS+MiNT+XaAES).
scruss
Thu Nov 24, 2016 8:22 pm
DavidS wrote:… I banged up a quick html with < code > < / code > tags around the same code and it was indeed fixed width, so the problem is NOT Netsurf.
after I spend ages trying to find fault with NetSurf … You're right. It's a bug in phpBB's CSS. It's only the sort of thing that you'd find running a browser like NetSurf that uses a radically different CSS engine from other browsers. I've registered a bug on phpBB's tracker: CSS error in ".codebox code" definition
Return to “RISCOS”
Who is online
Users browsing this forum: No registered users and 1 guest
