Yep. USB is up and running as far as I can tell. At least it runs my Acer Revo wireless keyboard and mouse, a San Disk Fit 4gb (formatted to ADFS) drive thingy and the onboard ethernet port.
Fantastic work and a great start.
It was "just" the Synposys driver for the BCM2835 port:mahjongg wrote:It was never quite clear to me if Risc OS in general didn't support USB, or that it only couldn't handle the USB hardware of the PI.
pygmy_giant wrote:also - will it have I2C drivers?
I found this: http://www.acornusers.org/wishlist/show?cat=9 which says '- I2C is implemented on all riscos machines as far as I know. It's used to talk to the real time clock and cmos ram I think. As far as I can remember, RS482 is supported (at least I think it was on my A3000). CAN bus would be fairly easy to implement.' so that coud be a yes?
Hoping RISCOS could be a better faster replacement for bloated debian for robotics...?
The Binary blob is used by RISC OS. On power up the Blob is run, it sets up the GPU then boots the ARM processor and then the Operating System: Linux, RISC OS or other OS is loaded and run.trevj wrote: On a rather unrelated issue (regarding a conversation I believe we began elsewhere) I don't think the graphics output uses the Linux binary blob... but I could be wrong, in which case the ROOL forum would be the place to ask.
Have a look here:I had a look at the RISC OS download but couldn't quite understand the bit where it says run the boot system off a pen drive.
OK yes, the device boots the GPU first. But I don't know whether RISC OS then needs to use the binary blob again itself.arm2 wrote:The Binary blob is used by RISC OS. On power up the Blob is run, it sets up the GPU then boots the ARM processor and then the Operating System: Linux, RISC OS or other OS is loaded and run.
I wonder if the Blob is considered an operating system itself? Is it Linux like?
Generic OMAP port setup information 'Putting the HardDisc4 image onto a USB drive' is probably what's needed.Grumpy Mike wrote:Is there somewhere that describes putting it on a pen drive and what "it" is.
But that's to get full use of the GUI. You can simply type 'desktop' at the Supervisor prompt to move to the GUI, can't you (as with the BeagleBoard port)?svrsig wrote:To get a GUI you need a boot structure and that requires a RISC OS formatted pen drive onto which you copy the 'HardDisc4' image so that RISC OS can start up with a nice GUI desktop.
Yes.But that's to get full use of the GUI. You can simply type 'desktop' at the Supervisor prompt to move to the GUI, can't you
The blob runs a real time OS, not Linux.arm2 wrote:The Binary blob is used by RISC OS. On power up the Blob is run, it sets up the GPU then boots the ARM processor and then the Operating System: Linux, RISC OS or other OS is loaded and run.trevj wrote: On a rather unrelated issue (regarding a conversation I believe we began elsewhere) I don't think the graphics output uses the Linux binary blob... but I could be wrong, in which case the ROOL forum would be the place to ask.
Yes. The pre-alpha version is available now but this is not for new users. A much friendlier image is being worked on.will RISCOS be available for download soon?
There are clubs closer than London:pygmy_giant wrote:Exciting! Unfortunately I live in the North of England
