Kuro
Boot stops at smsc95xx without error
Tue Jan 22, 2013 5:15 pm
I followed this guide: http://wiki.gentoo.org/wiki/Raspberry_P ... tall_Guide to install Gentoo to my raspberry and, while booting, it just stops in this line:
[ 3.052569] smsc95xx v1.0.4
[ 3.116771] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:f7:69:6d
Full boot:
Uncompressing Linux... done, booting the kernel.
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.6.11+ ([email protected]) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #358 PREEMPT Tue Jan 15 00:45:33 GMT 2013
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine: BCM2708
[    0.000000] cma: CMA: reserved 16 MiB at 1b000000
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113792
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0xf bcm2708.serial=0xaff7696d smsc95xx.macaddr=B8:27:EB:F7:69:6D sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p3 rootfstype=ext4 elevator=deadline rootwait
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 448MB = 448MB total
[    0.000000] Memory: 432264k/432264k available, 26488k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xdc800000 - 0xff000000   ( 552 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc04e5460   (4982 kB)
[    0.000000]       .init : 0xc04e6000 - 0xc0506f24   ( 132 kB)
[    0.000000]       .data : 0xc0508000 - 0xc053c060   ( 209 kB)
[    0.000000]        .bss : 0xc053c084 - 0xc05e4738   ( 674 kB)
[    0.000000] NR_IRQS:330
[    0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.001008] Calibrating delay loop... 464.48 BogoMIPS (lpj=2322432)
[    0.060062] pid_max: default: 32768 minimum: 301
[    0.060414] Mount-cache hash table entries: 512
[    0.061177] Initializing cgroup subsys cpuacct
[    0.061232] Initializing cgroup subsys devices
[    0.061265] Initializing cgroup subsys freezer
[    0.061295] Initializing cgroup subsys blkio
[    0.061387] CPU: Testing write buffer coherency: ok
[    0.061718] hw perfevents: enabled with v6 PMU driver, 3 counters available
[    0.061859] Setting up static identity map for 0x39d198 - 0x39d1f4
[    0.063355] devtmpfs: initialized
[    0.074097] NET: Registered protocol family 16
[    0.080537] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.081630] bcm2708.uart_clock = 0
[    0.082961] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.083015] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.083053] mailbox: Broadcom VideoCore Mailbox driver
[    0.083146] bcm2708_vcio: mailbox at f200b880
[    0.083247] bcm_power: Broadcom power driver
[    0.083285] bcm_power_open() -> 0
[    0.083311] bcm_power_request(0, 8)
[    0.584001] bcm_mailbox_read -> 00000080, 0
[    0.584041] bcm_power_request -> 0
[    0.584069] Serial: AMBA PL011 UART driver
[    0.584213] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[    0.908017] console [ttyAMA0] enabled
[    0.931485] bio: create slab <bio-0> at 0
[    0.936372] SCSI subsystem initialized
[    0.940470] usbcore: registered new interface driver usbfs
[    0.946055] usbcore: registered new interface driver hub
[    0.951646] usbcore: registered new device driver usb
[    0.957984] Switching to clocksource stc
[    0.962228] FS-Cache: Loaded
[    0.965372] CacheFiles: Loaded
[    0.980182] NET: Registered protocol family 2
[    0.985460] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.993192] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[    0.999980] TCP: Hash tables configured (established 16384 bind 16384)
[    1.006582] TCP: reno registered
[    1.009835] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.015731] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.022311] NET: Registered protocol family 1
[    1.027172] RPC: Registered named UNIX socket transport module.
[    1.033215] RPC: Registered udp transport module.
[    1.037939] RPC: Registered tcp transport module.
[    1.042684] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.049793] bcm2708_dma: DMA manager at f2007000
[    1.054579] bcm2708_gpio: bcm2708_gpio_probe c0515d98
[    1.060043] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    1.069190] audit: initializing netlink socket (disabled)
[    1.074789] type=2000 audit(0.930:1): initialized
[    1.197578] VFS: Disk quotas dquot_6.5.2
[    1.201615] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.208672] FS-Cache: Netfs 'nfs' registered for caching
[    1.214418] NFS: Registering the id_resolver key type
[    1.219588] Key type id_resolver registered
[    1.223884] Key type id_legacy registered
[    1.228247] msgmni has been set to 876
[    1.233766] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.241472] io scheduler noop registered
[    1.245519] io scheduler deadline registered (default)
[    1.250703] io scheduler cfq registered
[    1.274828] Console: switching to colour frame buffer device 82x26
[    1.286252] kgdb: Registered I/O driver kgdboc.
[    1.293429] vc-cma: Videocore CMA driver
[    1.299238] vc-cma: vc_cma_base      = 0x00000000
[    1.305821] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.313016] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.328992] brd: module loaded
[    1.338697] loop: module loaded
[    1.343922] vchiq: vchiq_init_state: slot_zero = 0xdb000000, is_master = 0
[    1.353284] Loading iSCSI transport class v2.0-870.
[    1.360852] usbcore: registered new interface driver smsc95xx
[    1.368528] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.581091] Core Release: 2.80a
[    1.586016] Setting default values for core params
[    1.592563] Finished setting default values for core params
[    1.804946] Using Buffer DMA mode
[    1.809950] Periodic Transfer Interrupt Enhancement - disabled
[    1.817473] Multiprocessor Interrupt Enhancement - disabled
[    1.824755] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.830801] Dedicated Tx FIFOs mode
[    1.837347] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.844082] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.853234] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    1.860491] Init: Port Power? op_state=1
[    1.866135] Init: Power Port (0)
[    1.871151] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.879814] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.888910] usb usb1: Product: DWC OTG Controller
[    1.895489] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[    1.903095] usb usb1: SerialNumber: bcm2708_usb
[    1.910160] hub 1-0:1.0: USB hub found
[    1.915788] hub 1-0:1.0: 1 port detected
[    1.922011] Initializing USB Mass Storage driver...
[    1.928915] usbcore: registered new interface driver usb-storage
[    1.936728] USB Mass Storage support registered.
[    1.943252] usbcore: registered new interface driver libusual
[    1.951040] mousedev: PS/2 mouse device common for all mice
[    1.959136] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[    1.964995] bcm2835-cpufreq: switching to governor powersavebcm2835-cpufreq: switching to governor powersave
[    1.978397] cpuidle: using governor ladder
[    1.986152] cpuidle: using governor menu
[    1.991858] sdhci: Secure Digital Host Controller Interface driver
[    1.999835] sdhci: Copyright(c) Pierre Ossman
[    2.006046] sdhci: Enable low-latency mode
[    2.052320] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    2.063875] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    2.073797] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.087123] usbcore: registered new interface driver usbhid
[    2.094719] usbhid: USB HID core driver
[    2.105222] TCP: cubic registered
[    2.112699] Indeed it is in host mode hprt0 = 00021501
[    2.121926] Initializing XFRM netlink socket
[    2.128232] NET: Registered protocol family 17
[    2.152258] Key type dns_resolver registered
[    2.158786] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    2.193019] registered taskstats version 1
[    2.199178] mmc0: could read SD Status register (SSR) at the 2th attempt
[    2.212927] Waiting for root device /dev/mmcblk0p3...
[    2.240563] mmc0: new high speed SDHC card at address e624
[    2.253900] mmcblk0: mmc0:e624 SU16G 14.8 GiB
[    2.264020]  mmcblk0: p1 p2 p3
[    2.372162] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.381793] Indeed it is in host mode hprt0 = 00001101
[    2.602427] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.611202] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.622758] hub 1-1:1.0: USB hub found
[    2.629915] hub 1-1:1.0: 3 ports detected
[    2.653461] EXT4-fs (mmcblk0p3): recovery complete
[    2.662167] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[    2.674125] VFS: Mounted root (ext4 filesystem) on device 179:3.
[    2.690854] devtmpfs: mounted
[    2.696335] Freeing init memory: 128K
[    2.912330] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.022831] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.031781] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
I tried from a Tt PSU so I don't think it's a power issue, and it booted just fine with raspbian (even with a Samsung Galaxy charger).
I also waited for more than 5 minutes, but it didn't go past that line.
Seems like it's failing to load this smsc95xx thing. Any Idea how I could fix it? Thank you.
lude
Re: Boot stops at smsc95xx without error
Tue Jan 22, 2013 11:49 pm
Have you tried it with smsc95xx.turbo_mode=N in /boot/cmdline.txt
Kuro
Tue Jan 22, 2013 11:58 pm
lude wrote:Have you tried it with smsc95xx.turbo_mode=N in /boot/cmdline.txt
Yeah. I've tried vm.min_free_kbytes = 4096 in /etc/sysctl.conf too.
Kuro
Wed Jan 23, 2013 1:35 am
I've now tried using the other kernel (the one from Raspbian 2012-12-16, which worked for me) and got the same problem, so I don't think it's the kernel.
josue549
Sat May 18, 2013 3:35 pm
Hello I have the same problem, do you found how to fix it ? :(
mahjongg
Sat May 18, 2013 3:37 pm
sounds like a defective LAN9512 (ethernet+hub) chip, that hangs the driver.
Sat May 18, 2013 4:33 pm
Did you try pressing the Enter key to see if it does anything?
johansaji
Sat Nov 15, 2014 4:59 pm
I am having the same problem. I am using the kernel version 3.12.28. I followed the instruction from http://elinux.org/Raspberry_Pi_Kernel_Compilation. When i boot the pi with new kernel that I have compiled i am getting the same logs and hangs. With the same setup I have booted the pi using the wheezy image from the site and it works properly. This confirms this is not an issue of faulty chip or power-supply. Did any one managed to solve this issue?? :?: Please help..
jbowler
Sat Jan 10, 2015 2:07 am
That's not the problem: it worked, the Ethernet device registered just fine
But it was already trying to run 'init' off the boot device, and nothing happened; so it found init (which would normally be the path /etc/init or /sbin/init maybe these days on the root / device), but nothing happened. (Look at the source code, I mean, it's terrible, but by that stage it's pretty clear what it's doing ;-)
I find it weird that the kernel reports itself as a Linaro kernel; mine says it is a Gentoo kernel, maybe that's because I built it on Gentoo, I'm not sure. Make sure you are using the one off github; the Gentoo raspberry pi kernel is way out of date it looks like whoever submitted it has moved on to something else. I recommend 3.18, that may seem brave but everything I've tried prior to that has serious issues with paging (not that this is anything to do with the problem here.)
My best guess is that is whatever is on mmcblk0p3 in or around /sbin/init is broken, somehow. Are you sure you used the right (armv6j -hardfp) stage3 to initialize the rootfs?
John Bowler
Return to “Gentoo”
