haaldemir
ntfs problem
Mon Dec 09, 2019 2:18 pm
I am receiving ntfs volume ""failed to mount "...."
error mounting /dev/sdb1 at run media/demouser/... wrong fs type, bad option, bad superblok on dev/sdb1, missing codepage or helper program, or other error""
This is 500 gb seagate external 2.5 inch hdd ntfs format. Rasbian can see it withou problems. i can not reach from gentoo.
Regards
gkaiseril
Re: ntfs problem
Mon Dec 09, 2019 2:43 pm
Have you installed the NTFS helper program, NTFS-3G?
Raspberry Pi NTFS: Adding Support for NTFS File System
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
haaldemir
Re: ntfs problem
Mon Dec 09, 2019 2:59 pm
Hi gkaiserli
Thank you for your reply. No i did not because i dont know how. It is not accept rasbian command (apt-get) İ can not find command about it. The link you write i can not find ntfs 3g. Can you write me about ntfs-3g
gkaiseril
Re: ntfs problem
Mon Dec 09, 2019 3:04 pm
Unless you are a root user, you must use the "sudo" command to install that package or any package.
"apt-get" is the command to update and upgrade raspbian, so I find it hard to believe it does not work.
jahboater
Re: ntfs problem
Mon Dec 09, 2019 3:08 pm
This is gentoo not debian.
dustnbone
Re: ntfs problem
Mon Dec 09, 2019 3:14 pm
https://wiki.gentoo.org/wiki/Portage
Gentoo uses Portage instead of apt
haaldemir
Re: ntfs problem
Mon Dec 09, 2019 3:15 pm
ok, i know now
so what is the code? about ntfs-3g
gkaiseril
Re: ntfs problem
Mon Dec 09, 2019 3:21 pm
See ntfs3g package for Gentoo for the download link.
haaldemir
Re: ntfs problem
Mon Dec 09, 2019 3:45 pm
i download it. thank you. How i can instal on gentoo?
gkaiseril
Re: ntfs problem
Mon Dec 09, 2019 3:59 pm
This forum is for primarily the Raspberry PI and the Raspbian operating system. You might want to switch to a Gentoo support forum.
Gentoo Cheat Sheet
sakaki
Re: ntfs problem
Mon Dec 09, 2019 4:39 pm
Try (as root):
# emerge -v sys-fs/ntfs3g
hth, sakaki
haaldemir
Re: ntfs problem
Mon Dec 09, 2019 4:54 pm
Try (as root):
hth, sakaki
Thank you this is it
Return to “Gentoo”
