QT issues
Posted: Sat Sep 07, 2019 10:15 am
by Gavinmc42
Hi Sakaki, I keep bumping into errors like this when compiling from source.
http://wiki.flightgear.org/TerraGear_GUI
This is not the only time I have run into this.
I think FreeCAD and others give the same or a similar error.
Is there some trick used to make ebuilds compared to cmake.
cmake has been very quick in Buster.
Somethings now work on Buster but are a pain in Gentoo64.
However Buster ones are not A72 optimised only armhf.
CMake Error at /usr/share/cmake/Modules/FindQt4.cmake:1324 (message):
  Found unsuitable Qt version "5.12.4" from /usr/bin/qmake, this code
  requires Qt 4.x
Call Stack (most recent call first):
  CMakeLists.txt:5 (FIND_PACKAGE)
-- Configuring incomplete, errors occurred!
See also "/home/demouser/terrageargui/build/CMakeFiles/CMakeOutput.log".
Re: QT issues
Posted: Tue Sep 10, 2019 10:56 am
by topguy
Qt4 is quite different from the standard Qt5 but it is still installable in Buster I think.
https://packages.debian.org/search?keyw ... ection=all
PS. Who is Sakaki ?
Re: QT issues
Posted: Tue Sep 10, 2019 11:35 pm
by Gavinmc42
PS. Who is Sakaki ?
The Hermione Granger of Gentoo64 on Pi's, a Linux Wizard ;)
The Champion of 64bit aarch64 Pi's.
The Wiki writer extraordinaire.
Re: QT issues
Posted: Thu Sep 12, 2019 8:16 pm
by sakaki
Gavinmc42,
Unfortunately, Qt4 was last-rited and removed in Gentoo last year (https://bugs.gentoo.org/631788).
However, the Qt ensemble is still slotted, so if you can install an overlay (user ebuild repository) that has the old Qt4 ebuilds in there, you ought to be able to install it in parallel with your existing Qt5 libs.
The bug report above mentions the kde-sunset overlay, which seems to have e.g. a qtcore:4 ebuild etc, so you could try installing that.
hth, sakaki
Re: QT issues
Posted: Fri Sep 13, 2019 9:11 am
by Gavinmc42
Or I can wait for all the PY3/QT5 etc issues to get sorted by the developers of those apps :lol:
I feel no need to go backwards and someine smarter will figure it out eventually.
Anyway found a Gentoo guy interested in 3D CAD stuff, will try some of these.
https://github.com/waebbl/waebbl-gentoo ... er/TODO.md
With Pi4's more Linux apps do just run, just a matter of going through the big list.
I probably won't run out of things to try.
Re: QT issues
Posted: Fri Sep 13, 2019 11:21 am
by sakaki
That was certainly the reasoning behind last-riting it (although there's still a fair amount of Qt4 stuff floating around out there).
Best, sakaki
PS I'd be interested in any feedback / bugs / issues on the newly released raspbian-nspawn-64 ("dual Debian" as I think you were calling it before ^-^): v1.3.0 now supports the Pi4, official 64-bit kernel, Buster host OS etc. Many thx, S.
Re: QT issues
Posted: Sat Sep 14, 2019 5:14 am
by Gavinmc42
Dual 32/64Bit Buster? Good point, I do need to test that more.
Time to build that mini bramble cluster.
Debian builds are easier even if they are not up to date as much as Gentoo.
Two different OS's might give clues to why one is better/fix the other.
