modulix
HOWTO : systemd - Gnome
Mon Feb 13, 2017 11:37 pm
I start this thread to publish some news about a Gentoo image including systemd+Gnome.
My last build :
Linux gentoo 4.4.47-v7+ #15 SMP PREEMPT Mon Feb 13 20:51:32 CET 2017 armv7l ARMv7 Processor rev 4 (v7l) BCM2709 GNU/Linux
This kernel was build from sources, i have tested with success Ethernet, WIFI, Bluetooth and Webcam interfaces.
In this configuration, the vc4 kernel module is enabled, so you can also use VideoCore :
# lsmod
Module Size Used by
cmac 2811 2
ecb 2127 1
bnep 10340 2
hci_uart 17943 1
evdev 11104 4
hid_logitech_hidpp 10318 0
brcmfmac 185901 0
hid_logitech_dj 9952 0
brcmutil 5725 1 brcmfmac
i2c_bcm2708 4834 0
bcm2835_gpiomem 2972 0
bcm2835_wdt 3225 0
uio_pdrv_genirq 3164 0
uio 8256 1 uio_pdrv_genirq
sch_fq_codel 8589 2
i2c_dev 5923 0
vc4 110328 26
drm_kms_helper 100929 2 vc4
drm_mipi_dsi 8702 1 vc4
drm 263326 11 vc4,drm_kms_helper
syscopyarea 2945 1 drm_kms_helper
sysfillrect 3443 1 drm_kms_helper
sysimgblt 2069 1 drm_kms_helper
fb_sys_fops 1309 1 drm_kms_helper
cfbfillrect 3443 1 drm_kms_helper
cfbimgblt 3285 1 drm_kms_helper
cfbcopyarea 3009 1 drm_kms_helper
snd_bcm2835 20319 1
snd_pcm 75454 1 snd_bcm2835
snd_timer 18708 1 snd_pcm
snd 51728 5 snd_bcm2835,snd_timer,snd_pcm
mac80211 550969 0
cfg80211 448360 2 brcmfmac,mac80211
btbcm 5891 1 hci_uart
bluetooth 325899 24 bnep,btbcm,hci_uart
rfkill 15930 6 cfg80211,bluetooth
ipv6 346768 40
For now, you can try to use my kernel .config file : https://github.com/modulix/raspggen/blo ... ernel.conf, instructions can be found on https://wiki.gentoo.org/wiki/Raspberry_ ... ompilation
in the future, i will try to publish a full image to avoid you 15 days long compilation...
cjan
Re: HOWTO : systemd - Gnome
Mon Feb 13, 2017 11:53 pm
wifi 8192cu(patched) support?
Return to “Gentoo”
