eazysnatch
Gentoo - Raspberry Pi 3 - MacOSX
Mon Jan 23, 2017 11:16 pm
Hello ,
I'm trying to setup emerge and kernel compilation to use my x86 OS X machine. The goal is to offload my Pi and use my other machines power. I never setup cross compiler till now i have experience with Distcc ~30 machines compiling for me but they all was same arch.
I already test to compile code on OS X and I move it to Raspberry and its working.
#### Compile the code on OS X machine:
{12:12}g1r5-hack:~/[email protected]✗✗✗✗✗✗ vhristev$ /usr/local/linaro/arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc -g -o hello hello.c
#### Move the code to Raspberry Pi 3
{12:14}g1r5-hack:~/[email protected]✗✗✗✗✗✗ vhristev$ scp hello [email protected]:~/
#### Test the code on Raspberry
g1r5-berry vhristev # ./hello
Hello World
#### END
The problem is when distcc send something to my OS X i receive error below. Does anyone have place to follow how i can compile my kernel on my PI and offload it with distcc to OS X. I know i can compile the kernel on OS X and then move it to PI but i don't want to do that.
Error from OS X:
(dcc_execvp) ERROR: failed to exec armv7a-hardfloat-linux-gnueabi-gcc: No such file or director
I follow this wiki:
https://wiki.gentoo.org/wiki/Raspberry_ ... g#crossdev
I just want to use emerge and kernel compile from Raspberry and my OS X to help out and at some point I can put in the chain my MacBook Pro
After i achieve OS X cross compilation I will try to add my Synology 1515+ .
Return to “Gentoo”
