Page 1 of 2
Feedback for my gentoo disk image (deutsch)
Posted: Thu May 12, 2016 2:01 pm
by shorty
i build a gentoo out of the box solution for rpi2, use the benefits of gentoo .
i dont have options to test this raw disk image working for other users, pls give some feedback if you are interested in ...
what works, what not ... and things you want to have on a newer release
Good for users that don't want waste time by building linux ... including everything you need to get started
you can download it from
https://www.linuxweb.net/dwnld_image.php
it's german! Userlogin same like in raspbian ...
some informations here: http://raspberry.linuxweb.net/?id=rpi2compatibilitylist
you can add packages that are available in portage ... feel free!
Greetings
Shorty
Re: Feedback for my disk image
Posted: Fri May 13, 2016 8:26 am
by shorty
i will buy a rpi3 to see if the image is portable
and make the wlan work
Posted: Thu May 19, 2016 8:47 am
by shorty
merged software: http://linuxweb.net/dwnld/world (world)
i think there is no 64bit kernel available so far for rpi3, else please contact me ...
or i have to build it by myself??
Re: Feedback for my disk image (deutsch)
Posted: Mon May 30, 2016 5:08 pm
by shorty
is it working on your rpi?
Posted: Fri Sep 23, 2016 11:53 pm
by cjan
does it wireless support by default, Rpi2?
Posted: Sun Sep 25, 2016 5:44 am
by shorty
wlan is in! any module that is available in kernel 4.4.18 should be working but must be loaded, the Vilros WLAN-Adapter is set up by default.
Use /etc/conf.d/modules and add it in right order, try pluggin it in..
lsusb:
Bus 001 Device 005: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
What Wlan Adapter are you using? I can add it in the next release ...
It would be nice if some other user can tell me about what adapters they are using!
i want to have an overview ...
Have a nice day !
Posted: Sun Sep 25, 2016 8:33 am
by cjan
one problem, too big to download...downloading break during about 1.3g.
Posted: Sun Sep 25, 2016 8:55 am
by shorty
sorry, server crashed, try http://linuxweb.net:8080/dwnld_image.php instead
perhaps somebody is able here to provide this file elsewhere, i'd like to get the count of the downloaded file in certain intervals
an update is neccessary, it's outdated - but you can do it by yourself too ...
Posted: Sun Sep 25, 2016 11:06 am
by cjan
ok, will wait next update.
Re: Feedback for my gentoo disk image (deutsch)
Posted: Mon Sep 26, 2016 8:48 am
by shorty
i' ve problems compiling omxplayer from portage in case of wrong included headers from userland ...
but a new release is online without the movieplayer ;)
Posted: Mon Sep 26, 2016 12:46 pm
by cjan
ok, need md5sum to make sure is it correct?
can not mount root fs during booting....
Posted: Mon Sep 26, 2016 2:12 pm
by shorty
ok, do you see any messages
Posted: Mon Sep 26, 2016 5:56 pm
by cjan
shorty wrote:ok, do you see any messages
where is md5sum ????
Posted: Tue Sep 27, 2016 6:56 am
by shorty
here it goes:
7dafbeed0d30bf4267587c6974f77bfa gentoo.img.gz
Posted: Tue Sep 27, 2016 7:24 am
by cjan
md5sum check ok.
but, mmcbl0p3 is 5XG > my 16G card after flashed.
wonder you had test yourself?
Posted: Tue Sep 27, 2016 7:57 am
by shorty
thank you for telling me, i've tested with a previous release with a big card
did you resize fs?
is it booting?
I'll fix this
Posted: Tue Sep 27, 2016 8:18 am
by cjan
shorty wrote:thank you for telling me, i've tested with a previous release with a big card
did you resize fs?
is it booting?
I'll fix this
mmcblk0p3 error, can not boot so no resize-card.
and, can not open inbox message you send.
btw, is it possible to setup wireless (no wired) form stage3?
Posted: Tue Sep 27, 2016 1:27 pm
by shorty
not that i know of, perhaps in other archs
if not that would be a nice feature, inform me when it is possible
iwconfig isn't present, ifconfig is
i think there is missing some things
you have the loopback by default
Posted: Mon Oct 03, 2016 4:50 pm
by shorty
it still takes time!
Posted: Tue Jan 03, 2017 1:12 pm
by shorty
i am currently working on a new release, with fixed filesystem and partition:
for those who using the old image this should help:
you should use gparted or parted!
new on next image:
display link, dual monitors, newer kernel.
Posted: Sat Jan 07, 2017 3:21 pm
by shorty
look & feel:openbox theme, icons and gtk theme
Posted: Sun Jan 08, 2017 7:52 am
by cjan
shorty wrote:look & feel: openbox, icons and gtk theme
new img download link ?
Posted: Sun Jan 08, 2017 10:05 am
by shorty
still compiling: coming soon
Posted: Fri Jan 13, 2017 11:02 am
by shorty
i think about using F2FS instead of ext4
Posted: Mon Jan 23, 2017 8:39 am
by shorty
Hey,
a new image is online, but i couldn't test it by myself yet because i'm busy with other work and i done this by remote.
it's about ~3 gb. the partition table is fixed but i can't move the main partition to other blocks, so there may be problems @ boot again when using a 8gb card. So 16 gb is recommended to be safe.
When anybody is going to test it and let me know if the image and booting is OK . Then i can go further make it done.
click here to download
checksum: 4075a1514561cb9e56590b4340aad540
gunzip -c gentoo.img.gz | dd of=/dev/sdX
 # X is your disk
there are several issues but not kind of high priority ... i must switch to another clock system (clock skew warnings / swclock or turn time to future, runlevel script as 1st)
openrc-run coming soon ..
Greetings + success
