ALHarake
Gentoo for raspberry pi 3
Tue Apr 19, 2016 7:54 pm
I would like if anyone has tried gentoo on raspberry pi 3, I googled a little but didn't find any results.
Is there any tutorial that explains how to compile it for rpi3 ?
I'm also interested in knowing how would it perform if the gentoo was compiled without a GUI, (to be used for embedded applications)
Thanks in advance
EvadingGrid
Re: Gentoo for raspberry pi 3
Sun May 08, 2016 9:07 am
Yes I have installed Gentoo on a Raspberry Pi 3.
The recipe uses NOOBS and Raspbian for a Dual Boot.
Raspbian is used to do a "normal" install and as a Rescue Disc.
stage3-raspberry-pi-2.tar.bz2
The kernel is raspberry pi foundation.
At present, no 64-bit kernels are available, or 64-bit stage-3. People are working on this, but so far nobody has succeeded. Its also not guaranteed that 64-bit is necessarily automatically "better".
The Instructions are here :
http://www.ukginger.net/Gentoo2/
The tutorial gives links to info on Over Clocking, and finishes with a raw but bootable copy of Gentoo. Its quick, but leaves you with hints how to use Git to pull in kernel and source code. I managed to load X Windows, Fluxbox and a Browser. Its much faster that Raspbian.
Return to “Gentoo”
