Enki
Install Arch from Windows
Thu Oct 09, 2014 10:53 pm
Is there a way to install Arch to an SD card from within Windows without NOOBS? I can't seem to find an img of the distro, only tarball. Also, I don't have a Linux system, so that makes all the other guides I've found less than useful (as they all require Linux commands).
I had it working just fine with NOOBS, but I'd rather have the simplest, fastest booting install I can get for this project.
Thanks!
Re: Install Arch from Windows
Thu Oct 09, 2014 11:13 pm
Unpack the Arch Download with 7Zip, eventually will have an .IMG file. Use Win32DiskImager to create an SD Card from the image file.
RPi 4B 4GB (SSD Boot)..
Enki
Thu Oct 09, 2014 11:21 pm
I'm using IZArc. If I open the tar.gz file, the only sub file is a tar file. If I open that, I get a directory structure with the three following files:
share
usr
Inside the . directory is the rest of the folder structure, containing directories like boot, dev, home, usr, var, etc. There's no img file anywhere, and the file name is ArchLinuxARM-2014.10-rpi-rootfs.tar.gz which unlike the other links from http://www.raspberrypi.org/downloads/ is neither a zip nor has img in the file name.
As a side note, the downloads from the Arch site do not have a source img file either, only a tarball.
Thu Oct 09, 2014 11:24 pm
Get the zip file from: http://downloads.raspberrypi.org/arch_latest
Get 7zip from: http://www.7-zip.org/
Edit: it looks like the Raspberry Pi download site is broken and the stuff that comes from the ZIP link isn't the ZIP file version
Enki
Thu Oct 09, 2014 11:29 pm
DougieLawson wrote:Get the zip file from: http://downloads.raspberrypi.org/arch_latest
It just gives me the same tarball I already have.
DougieLawson wrote:Get 7zip from: http://www.7-zip.org/
Even though I know this isn't the issue, I went ahead and got it anyways. Still no img file inside the tarball...
Thu Oct 09, 2014 11:40 pm
http://downloads.raspberrypi.org/arch/images
Maybe download an older release then fully update ??
Thu Oct 09, 2014 11:46 pm
I tried the torrent download and it's just as broken.
I've sent an email to info@raspberrypi.org (hopefully they can un-break this).
Enki
fruitoftheloom wrote:http://downloads.raspberrypi.org/arch/images
This is something I didn't see; I'll try it, thanks! As a side note, how did you dig this link up?
Thu Oct 09, 2014 11:47 pm
http://downloads.raspberrypi.org/arch/i ... pi.img.zip
should work on a B or B+.
Thu Oct 09, 2014 11:49 pm
Just look at the URL the download is linked to it is not rocket science....
Thu Oct 09, 2014 11:50 pm
Thank you for taking my link one step further, that was a surprise :roll:
pepedog
Fri Oct 10, 2014 10:15 am
That will probably be the last img supplied by ArchLinuxArm.
It's not that hard to create an image without even sight of a card.
Comments on this best put to http://archlinuxarm.org/forum/
Fri Oct 10, 2014 11:50 am
pepedog wrote:That will probably be the last img supplied by ArchLinuxArm.
Hi why the change ?
Maybe there are other changes coming ?
How are novices going to install Arch ?
pepedog
Fri Oct 10, 2014 11:58 am
The owner of ArchLinuxArm decided, it might be best to ask on other forum
Fri Oct 10, 2014 12:13 pm
pepedog wrote:The owner of ArchLinuxArm decided, it might be best to ask on other forum
That is fair enough and thanks for reply Pepedog :D
Personally as I do not use Windows this page suffices for me if need to create an SD Card http://archlinuxarm.org/platforms/armv6/raspberry-pi
Enki
Fri Oct 10, 2014 5:55 pm
Arch isn't terribly hard to work with (there's tons of guides out on the web) and I've got all but one thing I need working on it (auto-run raspivid on user logon, which has already been made automatic), but even a quick blurb somewhere about how to create an iso from the tarball would be majorly beneficial.
As it stands, this thread should mostly take care of it for new people that don't want to use NOOBS, but if that archival iso ever goes away then a quick blurb about how to turn a tarball into an iso would be beneficial.
Joe Schmoe
Fri Oct 10, 2014 5:59 pm
Since there's no way to boot a Raspberry Pi from a CD or DVD, it is unlikely that an ISO file would do anyone any good. Why do you think you need one?
Enki
Fri Oct 10, 2014 9:06 pm
Win32 disk imager.
Fri Oct 10, 2014 9:43 pm
Win32 disk imager.
Win32DiskImager
This utility is used to write img files to SD and USB memory devices.
Simply run the utility, point it at your img, and then select the
removable device to write to.
http://sourceforge.net/projects/win32diskimager/files/
Still confused what an ISO has to do with this
..ort this
:roll:
Enki
Fri Oct 10, 2014 9:45 pm
fruitoftheloom wrote: Win32DiskImager
:roll:
I meant img. I'm sure it wouldn't be hard for someone like you to make that leap. :roll:
Fri Oct 10, 2014 10:01 pm
Enki wrote:I meant img. I'm sure it wouldn't be hard for someone like you to make that leap. :roll:
There are many people on this forum who could not make the leap that is why firstly DL queeried your quote and as you failed to respond I felt it was appropriete to straighten out any ambiguity, apologies if offended
Enki
Fri Oct 10, 2014 10:05 pm
I don't normally work with either img or iso files, so I wind up making the noob error of using them interchangeably, as I've always thought that isos were just images of cds/dvds.
Fri Oct 10, 2014 10:09 pm
Enki wrote:I don't normally work with either img or iso files, so I wind up making the noob error of using them interchangeably, as I've always thought that isos were just images of cds/dvds.
WHATEVER :D
pepedog
Sat Oct 11, 2014 1:34 pm
Enki wrote:As it stands, this thread should mostly take care of it for new people that don't want to use NOOBS, but if that archival iso ever goes away then a quick blurb about how to turn a tarball into an iso would be beneficial.
Here is a script that makes img without a card, I guess 4Gb free space would be needed if using a pi, it creates zip also (you might not want that?)
#!/bin/bash
# Packages required
# dosfstools parted
# Can be run on any Linux system
# loop.max_part=15 must be in kernel cmdline (cmdline.txt for rpi)
# then reboot
echo "creating image to fit on 2Gb card"
dd if=/dev/zero of=arch-rpi.img bs=1M count=1850
echo "Partitioning"
fdisk arch-rpi.img <<EOF
o
n
p
1
+100M
t
c
n
p
2
w
EOF
sleep 5
losetup -f arch-rpi.img
sleep 5
echo "Formatting vfat"
mkfs.vfat /dev/loop0p1
sleep 5
mkdir boot
echo "Mounting boot"
mount /dev/loop0p1 boot
echo "Installing"
echo "Formatting ext4"
mkfs.ext4 /dev/loop0p2
sleep 5
mkdir root
echo "Mounting root"
mount /dev/loop0p2 root
wget http://archlinuxarm.org/os/ArchLinuxARM-rpi-latest.tar.gz
echo "Installing"
bsdtar -xpf ArchLinuxARM-rpi-latest.tar.gz -C root
sync
mv root/boot/* boot
sync
umount boot root
losetup -d /dev/loop0p1
echo "All complete, image arch-rpi.img created, compressing...."
zip -9 arch-rpi.img.zip arch-rpi.img
Tue Oct 14, 2014 11:56 am
Return to “Arch”
