Bluetooth: main.conf seems to be ignored
Posted: Sun Sep 14, 2014 4:46 pm
I have a Cambridge Silicon bluetooth dongle for my airplay speaker, I'm trying to make it usable as a bluetooth speaker as well.
I'm having trouble configuring and pairing it. In particular, it seems that none of the config I put in main.conf are ignored: device name, class, discoverability...
Here is hciconfig -a hci0:
And my /etc/bluetooth/main.conf :
What can cause that, and where should I look to debug this?
[erwan@alarmpi ~]$ hciconfig -a hci0
hci0: Type: BR/EDR Bus: USB
BD Address: 00:15:83:0C:BF:EB ACL MTU: 339:8 SCO MTU: 128:2
UP RUNNING PSCAN ISCAN
RX bytes:1217 acl:0 sco:0 events:42 errors:0
TX bytes:672 acl:0 sco:0 commands:42 errors:0
Features: 0xff 0x3e 0x85 0x30 0x18 0x18 0x00 0x00
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH HOLD SNIFF
Link mode: SLAVE ACCEPT
Class: 0x000104
Service Classes: Unspecified
Device Class: Computer, Desktop workstation
HCI Version: 2.0 (0x3) Revision: 0xc5c
LMP Version: 2.0 (0x3) Subversion: 0xc5c
Manufacturer: Cambridge Silicon Radio (10)
[General]
# Default adaper name
# %h - substituted for hostname
# %d - substituted for adapter id
# Defaults to 'BlueZ'
Name = Jukebox
# Default device class. Only the major and minor device class bits are
# considered. Defaults to '0x000000'.
Class = 0x200420
# How long to stay in discoverable mode before going back to non-discoverable
# The value is in seconds. Default is 180, i.e. 3 minutes.
# 0 = disable timer, i.e. stay discoverable forever
DiscoverableTimeout = 0
# How long to stay in pairable mode before going back to non-discoverable
# The value is in seconds. Default is 0.
# 0 = disable timer, i.e. stay pairable forever
PairableTimeout = 0
# Automatic connection for bonded devices driven by platform/user events.
# If a platform plugin uses this mechanism, automatic connections will be
# enabled during the interval defined below. Initially, this feature
# intends to be used to establish connections to ATT channels. Default is 60.
#AutoConnectTimeout = 60
# Use vendor id source (assigner), vendor, product and version information for
# DID profile support. The values are separated by ":" and assigner, VID, PID
# and version.
# Possible vendor id source values: bluetooth, usb (defaults to usb)
#DeviceID = bluetooth:1234:5678:abcd
# Do reverse service discovery for previously unknown devices that connect to
# us. This option is really only needed for qualification since the BITE tester
# doesn't like us doing reverse SDP for some test cases (though there could in
# theory be other useful purposes for this too). Defaults to 'true'.
#ReverseServiceDiscovery = true
# Enable name resolving after inquiry. Set it to 'false' if you don't need
# remote devices name and want shorter discovery cycle. Defaults to 'true'.
#NameResolving = true
# Enable runtime persistency of debug link keys. Default is false which
# makes debug link keys valid only for the duration of the connection
# that they were created for.
#DebugKeys = false
#[Policy]
# The ReconnectUUIDs defines the set of remote services that should try
# to be reconnected to in case of a link loss (link supervision
# timeout). The policy plugin should contain a sane set of values by
# default, but this list can be overridden here. By setting the list to
# empty the reconnection feature gets disabled.
#ReconnectUUIDs=
