i have to add 8712u module to kernel for my usb wifi key.
i'm not really used at this( just done it on a gentoo), but as far as i know i have to recompile the kernel adding to module.
i don't want to cross-compile because actually on main system i have a chain for cortex4, so i want to recompile it directly on rasp (this also will remove some complication), probably it will take ages
i've seen some arch guide, with suggest the use of "abs", but anyway i need the configuration file. I'm doing right? where i can download the configuration file used for the image, so i'm sure i won't forgot some module/patch/whatever?
a confused bye
