michelinok
Unable to understand if RTL8191SU works...
Thu May 31, 2012 11:33 am
Hi there!
Just installed and updated arch.
The problem is with my usb dongle Realtek RTL8191SU...
1) No led blinkink at all...
2) ifconfig and iwconfig show the interface
3) iwlist scan doesn't report any wifi access points (there are A LOT of ap here...mine too!)
What can i check?
Many thanks!
http://www.iu5hes.it
michelinok
Re: Unable to understand if RTL8191SU works...
Fri Jun 01, 2012 5:53 am
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 004: ID 07d1:3303 D-Link System DWA-131 802.11n Wireless N Nano Adapter(rev.A1) [Realtek RTL8192SU]
jose1711
Fri Jun 01, 2012 10:24 am
i have 8192cu nano receiver and the kernel driver never worked for me (could not find anything). i always had to use this pkgbuild: http://aur.archlinux.org/packages.php?ID=49171
michelinok
Sat Jun 02, 2012 8:33 am
jose1711 wrote:i have 8192cu nano receiver and the kernel driver never worked for me (could not find anything). i always had to use this pkgbuild: http://aur.archlinux.org/packages.php?ID=49171
Can you (please) explain how to install this driver and blacklist the other?
Many many thanks! ;)
michelinok
Sat Jun 02, 2012 10:06 am
Ok...updates....
I've just updated with pacman to the latest firmware...
I can do ifconfig wlan0 up and the led now blinks...
BUT:
lsmod:
[[email protected] ~]# lsmod
Module Size Used by
ipv6 221660 10
r8712u 125628 0
and if i do iwconfig wlan0 essid "myssid":
Error for wireless request "Set ESSID" (8B1A) :
SET failed on device wlan0 ; Operation not permitted.
Any idea?
piglet
Sat Jun 02, 2012 8:20 pm
How do you get iwconfig working? It doesn't appear to be there on the arch download and pacman -S network-tools doesn't work
I've done a full update - but am rather lost with this distro. pointers would be appreciated.
What I want to do is get lxde and my wifi donge installed and working and to check whether the problem seen on Deb with hubs and wifi exists on this distro.
Return to “Arch”
