devnull
RTC Auto Update from NTPD
Tue Oct 15, 2013 11:23 pm
I have googled this and was surprised not to find any similar question / answer.
I understand that the system clock can be adjusted to the hwclock during bootup, however for a device which may not be rebooted for several months this is not practical and periodic syncing is needed to keep the hwclock current with the latest system time.
I kind of expected NTPD to do this automatically, however I can find no mention of any auto-update by NTPD to the hardware clock in any of the online articles including this one: https://wiki.archlinux.org/index.php/Ne ... col_daemon.
Is this not a feature / function of NTPD that can be enabled, if not, other than creating a cron job to execute hwclock -w once a day is there a better, already existing solution to do this ??
> /dev/null 2>&1
pepedog
Re: RTC Auto Update from NTPD
Wed Oct 16, 2013 12:23 am
hwclock -w was the path I would suggest. I see this problem with other arm hardware too.
One major thing I can tell you, don't put your thumb near a circular saw blade while it's running
Return to “Arch”
