okieng
TV is ON?
Tue May 14, 2013 1:30 pm
I already load libcec-rpi driver.
My PI connected samsung TV via HDMI. I want to check TV 's power status. TV is ON or OFF.
Can i do with libcec command?
Anyone have any idea?
Oki
richardp
Re: TV is ON?
Tue May 14, 2013 1:35 pm
yes you can.. but its riddled with problems..
1) You TV should support CEC
2) Some TV's shut down the HDMI port then its not selected on the TV (HDMI1, HDMI2) - In that case you get the HDMI disconnect.
3) Some TV's shut down the HDMI logic in Standby
Richard
RaspberryPi's galore
Solid run CuBox
ODroid U2
okieng
Re: TV is ON?
Tue May 14, 2013 8:43 pm
Thanks RichardP
Yes my TV is support CEC. I am wondering try it. Do you know what code to check TV/HDMI on or off?
Return to “Arch”
