Nikolai84D
asp.net
Sat Apr 13, 2013 3:44 pm
Hi there,
Im trying to install asp.net on RPi.
Im using arch and following this tutorial:
http://www.simbiosys.co.uk/asp.net-on-the-raspberrypi
so ive installed "pacman -S nginx mono fcgi xsp"
and created /etc/nginx/conf/nginx.conf and /etc/nginx/conf/fastcgi_params myself and copypasted the code from the site in this files.
But next if i try to do this commands:
"/etc/rc.d/nginx start"
"fastcgi-mono-server4.exe /applications=/:/srv/http/site/ /socket=tcp:127.0.0.1:9000 &"
They dont do anything for me. Only "no such file or directory is what i get".
Any suggestions?
thans in advance,
Nikolai
drirr
Re: asp.net
Sun Apr 14, 2013 6:56 am
Arch doesn't use initscripts anymore, those have been deprecated in favour of systemd. To start nginx use "systemctl start nginx" (assuming the service file is called nginx.service (pacman -Ql nginx|grep '.service' can tell you the name if not)). As for the second command I have no ideas, looks very odd to try and start an windows executable like that. Is there even such an executable? You can check the file contents from the mono package with "pacman -Ql mono", anything that is installed under /usr/bin/ should be executable.
Raspberry Pi (rev 000f, 512MB RAM) with heatsinks and a modmypi case running Arch Linux ARM (armv6h) hooked up to a 750GB 2.5" USB-harddrive
Return to “Arch”
