qobix
Reduce Arch to a minimum
Wed Mar 20, 2013 5:33 pm
Hi all,
I'm doing a new project and is working ok, but, I want to reduce the size to a minimum removing all unnecessary programs, files, service, etc... I'm using some programs like lighttpd (http server), ftp server, ffpmeg.. etc but I think I don't need a lot of libraries, programs etc.. How can I do to remove all but the programs I'm using and keep the system working properly?? Any automated program or something like this??
Thanks in advance.
-rst-
Re: Reduce Arch to a minimum
Fri Mar 22, 2013 11:39 am
Afaik, Arch is supposed to be very minimal by default... I suppose you could use the pacman package manager to list installed packages and to remove if needed. Might better belong to the Arch sub-forum http://www.raspberrypi.org/phpBB3/viewforum.php?f=53 ?
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
drirr
Fri Mar 22, 2013 3:47 pm
You can run "pacman -Qdt" (man pacman) to query the database of installed packages for items that were installed as a dependency for some package but aren't needed anymore. You can also run "pacman -Qet" to list all explicitly installed packages and see if there is anything you wish to remove.
Raspberry Pi (rev 000f, 512MB RAM) with heatsinks and a modmypi case running Arch Linux ARM (armv6h) hooked up to a 750GB 2.5" USB-harddrive
Return to “Arch”
