jackhez
archlinux-hf-2012-09-18.img set ramsize promblem,modle b
Tue Feb 12, 2013 3:40 am
I fired the image to sdcard. then boot the PI, and use commend line type "top",i find out that archlinux just use 189Mb ram only. then i modify "/boot/config.txt" file, append "gpu_mem=16 \n gpu_mem_512=16", reboot it . use "top", but it was 189Mb ram.
how can i do ? i want archlinux to use 512ram.
Cloudcentric
Re: archlinux-hf-2012-09-18.img set ramsize promblem,modle b
Tue Feb 12, 2013 6:52 am
The image is very old, pre 512MB, maybe use the latest image ?
http://www.raspberrypi.org/downloads archlinux-hf-2013-02-11.zip
I know everything about nothing"
drirr
Tue Feb 12, 2013 5:00 pm
No need to rewrite the image to your SD-card, just run "pacman -Syu" to update your system.
Raspberry Pi (rev 000f, 512MB RAM) with heatsinks and a modmypi case running Arch Linux ARM (armv6h) hooked up to a 750GB 2.5" USB-harddrive
Return to “Arch”
