pepedog
New archlinuxarm image
Sun Feb 10, 2013 6:46 pm
Tomorrow I have to make a new one. There is a good reason for this, unavoidable but it's future hardware related.
For the same reason raspbian have new rootfs ready.
Get suggestions in quick
dk23
Re: New archlinuxarm image
Sun Feb 10, 2013 7:06 pm
add PPS support w/o debug to kernel:
Device Drivers → PPS Support
<M> PPS Support
< > PPS Debug
<M> lPPS line discipline
<M> PPS client using GPIO
add PPS GPIO to bcm2708.c:
There are a couple of patch files around one is:
https://raw.github.com/lampeh/rpi-misc/ ... m2708.diff
Thanks for asking.
dk23
cjan
Tue Feb 12, 2013 4:58 am
new image online, which improve? or just pacman -Syu?
Cloudcentric
Tue Feb 12, 2013 6:34 am
archlinux-hf-2013-02-11 http://downloads.raspberrypi.org/images thanks for heads up !
I know everything about nothing"
pepedog
Tue Feb 12, 2013 9:58 am
cjan - pacman -Syu will make you always good. The reason for new rootfs is they are shipping now with a different ram, if you got one the old image wouldn't boot. I'm sure there will be an announcment.
dk23 - will try to add next kernel update
cloudcentric - thanks
Only 2 things new in this rootfs
The hardware random generator is all set up
Changed netcfg way slightly
To make eth0 static edit /etc/network.d/ethernet-eth0 (this is unchanged)
systemctl enable netcfg is NOT how it was enabled, I used this instead (makes sense when I tell you how to get wireless going, editing of /etc/conf.d/netcfg no longer required)
systemctl enable [email protected]
To get wireless going edit /etc/network.d/wireless-wpa and edit just ESSID and KEY
Test with
systemctl start [email protected]
ifconfig
If that is ok, enable with
Possibly disable wired
systemctl disable [email protected]
I tested this with a nano 8192 dongle and time does get set
yakko TDI
Thu Feb 14, 2013 3:54 am
The newest torrent on the downloads page does not seem to be working. I am getting the following error.
Failure: Requested download is not authorized for use with this tracker.
The 2013-01-22 torrent is still working fine. I am using uTorrent on a Window 7 machine. Any ideas?
pepedog
Thu Feb 14, 2013 9:53 am
yakko TDI wrote:The newest torrent on the downloads page does not seem to be working. I am getting the following error.
I got someone to look at it
yakko TDI
Thu Feb 14, 2013 11:16 am
pepedog wrote:I got someone to look at it
And look at it they did. Downloaded and seeding now.
Return to “Arch”
