bartender
system.journal corrupted
Tue Jan 22, 2013 9:10 am
There's an issue which appears right after clean install and update (pacman -Syu).
During boot you see this message:
[   36.591060] systemd-journald[168]: File <...>/system.journal corrupted or uncleanly shut down, renaming and replacing.
(pasted from https://bbs.archlinux.org/viewtopic.php?id=150442&p=1)
Should we be concerned about it? I don't notice anything being missing from journal.
Also, since Pi doesn't have RTC, how does journalctl sort the lines? The output of "journalctl" has "Reboot" delimeter in weird places. If I launch "journalctl -b", the output is much more sane. Maybe it's the reason why syslong-ng is enabled by default.
pepedog
Re: system.journal corrupted
Tue Jan 22, 2013 10:29 am
I have spent many hours looking at this. There is no specific way of fixing, some have said changing media can fix, but it's harmless.
syslog-ng files are a bit easier to look thru, everything.log will have a cron entry every hour if things are ok
I got a fakeclock (not packaged) which puts date at last everything.log entry. I guess this might be good for model A?
mnemonic
Tue Apr 18, 2017 6:12 pm
I have same problem here...
..."File <...>/system.journal corrupted or uncleanly shut down, renaming and replacing." in dmesg
I think it is a bug in systemd...
Return to “Arch”
Who is online
Users browsing this forum: No registered users and 1 guest
