[Manjaro][SOLVED] I2C doesn't start with overlay settings
Posted: Mon Aug 10, 2020 4:57 pm
Hello everyone,
I'm testing my Argon One Daemon project on Manjaro Linux, My overlay should automatically load the I2C bus however this isn't working i tried to get it working with the manual into the config.txt however no joy.
I installed Manjaro with PINN as I wanted to test multiple OS's without using a bunch of SD cards. I've not used Arch much at all I would have thought the procedure to enable i2c would have been the same.
I read about using modprobe is this the only way?
param=i2c_arm=onI installed Manjaro with PINN as I wanted to test multiple OS's without using a bunch of SD cards. I've not used Arch much at all I would have thought the procedure to enable i2c would have been the same.
