DarkElvenAngel
[Manjaro][SOLVED] I2C doesn't start with overlay settings
Mon Aug 10, 2020 4:57 pm
Hello everyone,
I'm testing my Argon One Daemon project on Manjaro Linux, My overlay should automatically load the I2C bus however this isn't working i tried to get it working with the manual
param=i2c_arm=on
into the config.txt however no joy.
I installed Manjaro with PINN as I wanted to test multiple OS's without using a bunch of SD cards. I've not used Arch much at all I would have thought the procedure to enable i2c would have been the same.
I read about using modprobe is this the only way?
DarkElvenAngel
Re: [Manjaro][SOLVED] I2C doesn't start with overlay settings
Tue Aug 11, 2020 12:10 am
I solved it,
The answer was to create /etc/modules-load.d/raspberrypi.conf and add the following lines
i2c-dev
I2c-bcm2708
Now my project works.
Return to “Arch”
