Hello i have a argon one case with fan built inside for pi4.
I am using Manjaro KDE Os
There is a downloable script to activate the fan, but unfortunatly it is only writed for raspian os, so it doesn't work and i haven't no cpu refresh. I have tried to modify it and succeded to run a few part but it fails to call i think raspian specific command like vcgencmd. I haven't enough coding skills in bash or python to adapt and make it working.
I have write to argon. com but nothing at the moment.
Here is the link to download the bash script : https://download.argon40.com/argon1.sh
Are there talented persons able to adapt this script for Manjaro ??
In advance thanks
Re: Script for Argon one pi4 fan ???
Thanks for your link, in fact i ve already found it but i am a beginner in scripting, even reading at the doc, i am not sure how to properly install it.
Please could you tell me how to procede step by step ?
It will be kind of you
I've tried this :
git clone https://github.com/Elrondo46/argonone.git
cd argonone
sudo pacman -S base-devel (to install some missing packages)
makepkg -si
sudo systemctl enable argononed.service
sudo reboot
Everything installed properly, can access argonone-config from terminal, but fan still doesn't work..
cd argonone
makepkg -si
sudo reboot
tommy@RPi4-Manjaro ~]$ sudo systemctl status argononed.service
[sudo] password for tommy:
● argononed.service - Argon One Fan and Button Service
Loaded: loaded (/usr/lib/systemd/system/argononed.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Thu 2020-03-05 14:19:49 CET; 48s ago
Process: 1197 ExecStart=/opt/argonone/bin/python3 /opt/argonone/bin/argononed.py (code=exited, status=1/FAILURE)
Main PID: 1197 (code=exited, status=1/FAILURE)
Mar 05 14:19:49 RPi4-Manjaro systemd[1]: argononed.service: Scheduled restart job, restart counter is at 5.
Mar 05 14:19:49 RPi4-Manjaro systemd[1]: Stopped Argon One Fan and Button Service.
Mar 05 14:19:49 RPi4-Manjaro systemd[1]: argononed.service: Start request repeated too quickly.
Mar 05 14:19:49 RPi4-Manjaro systemd[1]: argononed.service: Failed with result 'exit-code'.
Mar 05 14:19:49 RPi4-Manjaro systemd[1]: Failed to start Argon One Fan and Button Service.
[tommy@RPi4-Manjaro ~]$
Don't know how to fix it...any help appreciated
Sorry, I can't help you. It just works here.
How does you /etc/argononed.conf file look like?
I've solved it..needed to install:
yay -S raspberrypi-userland-aarch64-git
works perfectly now!
Hello all !
Thank you very much hectorkvs, i've installed too yay first, then i've type your command to install raspberrypi-userland.
I've done this : systemctl enable argononed.service
sudo reboot
and it works !!!
sudo reboot
and it works !!!
Here is the proper way to install script for Argon One case running on Manjaro ARM both KDE Plasma and XFCE:
cd argonone
makepkg -si
sudo reboot
Make sure you put this in config.txt on boot partition before rebooting :
dtparam=i2c_arm=on
dtparam=i2c-1=on
enable_uart=1
Also I forgot to mention that the ' enable_uart=1 ' in /boot/config.txt in conjunction with having ' kgdboc=ttyAMA0,115200 ' mentioned in /boot/cmdline does crash the kernel (kernel panic) so please check for this if you are planning on automatically add the uart-option to /boot/config.txt.I did fix this by removing ' kgdboc=ttyAMA0,115200 ' from my /boot/cmdline.
If you have a problem with shuting down when the power isn't cut as it should (power led still working, after pi shutdown), you need to change in ' /usr/lib/systemd/system-shutdown/argononed-poweroff.py ' the following:
Line 20
bus.write_byte_data(0x1a,0,0) to looks like this..
hope this help
cd argonone
makepkg -si
sudo reboot
dtparam=i2c_arm=on
dtparam=i2c-1=on
enable_uart=1
Line 20
hope this help
Thank you very much i'll try to solve the led still working even the shutdown, i promise i'll tell you as soon as i can.
Hope u'll solve it...just go to /usr/lib/systemd/system-shutdown/argononed-poweroff.py open it in text editor and change the Line 20 to look like this:Alexandrapi4 wrote: ↑Wed Apr 22, 2020 1:04 pmThank you very much i'll try to solve the led still working even the shutdown, i promise i'll tell you as soon as i can.
Now the power led will power off when you shutdown your pi..
Does anyone know how I can make this work for Ubuntu?
I would also love to know how to get this working in Ubuntu.
Sort-of update:
I shot their customer support mailbox an email to ask if there were any plans to make an Ubuntu-friendly version of the script. Their response:
In the meantime you'll have to wait for their official script or for some enthusiast to cobble one together.
Removed, double post. See post below.
I adapted the original script to work on Ubuntu 20.04. You can find it on my github.
https://github.com/meuter/argon-one-case-ubuntu-20.04
Everything seems to work as advertised:
- double press of the power button reboots the board cleanly
- 3 second press of the power button shuts the board down cleanly
- using argonone-config, you can turn on the fan directly; works as expected
- using argonone-config, you can input new value for the fan curve to update the fan curve
- the service is registered so it starts automatically on boot.
Enjoy!
Enjoy!
hectorkvs wrote: ↑Wed Apr 22, 2020 1:59 amHere is the proper way to install script for Argon One case running on Manjaro ARM both KDE Plasma and XFCE:
cd argonone
makepkg -si
sudo reboot
dtparam=i2c_arm=on
dtparam=i2c-1=on
enable_uart=1
Line 20
hope this help
After the "sudo pacman -S base-devel" command, it returns "impossible to download the pkg. the requested URL returned error: 404".
Any way to solve this issue?
Thanks in advance
Fan control and power button worked perfectly on my Ubuntu Server 18.04 x MATEdrlemon3000 wrote: ↑Thu Jun 11, 2020 6:18 pmI adapted the original script to work on Ubuntu 20.04. You can find it on my github.
Enjoy!
Thanks for the great work!!
(didn't get to test the GPIO pins though... )
Yes, Hello, I also use "Manjaro arm", and I also have an aluminum alloy case, that is "Argon one", I installed the driver for fan control, from the" AUR " repository,it is fully functional,everything works,
but for some reason it does not start when you turn on the computer and I have to turn it on manually, could you help me how to add it to the initial system boot. Thank you for your answer =)
I don't think this is a software issue. It is by design. It happens for me too with Ubuntu, but I suspect it would happen on Raspberry OS too.Alex3500 wrote: ↑Thu Aug 20, 2020 9:19 amYes, Hello, I also use "Manjaro arm", and I also have an aluminum alloy case, that is "Argon one", I installed the driver for fan control, from the" AUR " repository,it is fully functional,everything works,
Aside from that, I am curious about the shutdown script - it seems to take the system down really fast so I am a little skeptical about how it's powering off the system.
Does anyone know of the same script for android?
Do you know if this modified Argon One script will work on Ubunto 20.10? Please advise, thanks.drlemon3000 wrote: ↑Thu Jun 11, 2020 6:18 pmI adapted the original script to work on Ubuntu 20.04. You can find it on my github.
Enjoy!
If you want something that works for multiple platforms I have good coverage with my project https://gitlab.com/DarkElvenAngel/argononed
I use C and not Python so my project will run on more operating systems. There is a topic here viewtopic.php?f=29&t=275713 where you can learn more.
Hi, I'm new to the Raspberry pi and Linux and have just bought a Pi 4 and ArgonOne M.2 case so this is perfect since I am trying to set up Manjaro on it. I have got as far as cloning the repo but can not work out how I use the "./configure && make all && sudo make install" command or where I run it from. Any help would be greatly appreciated.
Once you clone the repo you dodeanjm68 wrote: ↑Fri Nov 27, 2020 12:00 pmHi, I'm new to the Raspberry pi and Linux and have just bought a Pi 4 and ArgonOne M.2 case so this is perfect since I am trying to set up Manjaro on it. I have got as far as cloning the repo but can not work out how I use the "./configure && make all && sudo make install" command or where I run it from. Any help would be greatly appreciated.
cd argononed
That's it
