I'm posting this in the Arch section since there isn't a section of Manjaro, I hope it's fine.
I'm planning to install a Manjaro on my Raspberry Pi 4 (OS image here: https://manjaro.org/download/arm8-raspb ... 4-minimal/), but I don't have a screen nor a keyboard. With Raspbian I know how to enable SSH and setup my wifi information so I can then SSH into it. I couldn't find any instruction to do the same with Manjaro. Does anyone have any?
Re: Manjaro headless installation and wifi setup
Normally you would do something along the lines of:
But these will require a keyboard / monitor - maybe a family member / friend / work could loan you one for a short while to get you started?
Failing that, a TV and a cheap Amazon keyboard may do?
sudo pacman -S openssh
sudo systemctl enable sshd
sudo systemctl start sshd
Manjaro 64 bit is almost as fast as Gentoo 64 bit while booting up on a Pi4B-4
ssh was enabled by default ...
login as: geev03
geev03@192.168.1.188's password:
Welcome to Manjaro-ARM
~~Website: https://manjaro.org
~~Forum: https://forum.manjaro.org/c/manjaro-arm
~~IRC: #manjaro-arm on irc.freenode.net
~~Matrix: #manjaro-arm-public:matrix.org
[geev03@pi ~]$ uname -a
Linux pi 4.19.65-1-MANJARO-ARM #1 SMP PREEMPT Tue Aug 13 14:39:03 UTC 2019 aarch64 GNU/Linux
[geev03@pi ~]$ free -h
total used free shared buff/cache available
Mem: 3.7Gi 538Mi 2.7Gi 35Mi 480Mi 3.1Gi
Swap: 0B 0B 0B
[geev03@pi ~]$
I used the Manjaro Pi4 xfce version. The root password setup screen will follow ( the attached screen shot) the user setup.
- Attachments
- manjaro_pi4_setup.jpg (42.31 KiB) Viewed 7643 times
Ah so I will need a screen and a keyboard if there are installation steps to follow before being able to ssh. Thanks.
Keyboard and screen are both necessary for the initial boot of the minimal image. Ssh is enabled by default, but any attempt to log in via ssh results in a message asking you to finish the set-up procedure shown above (passwords, keyboard, time-zone etc). Once that's been completed the device will automatically reboot and can then be accessed via ssh.
Is the current release good enough for everyday use? I wish to use this as minecraft server / pihole / bitwarden client. Last I checked this release didn't have some kernel upstream changes that enabled hardware gpu acceleration. Will that cause any issues?
This is a heads-up. Latest version of Manjaro ARM (19.10) has headless setup enabled. If you flash your card, boot your Pi 4, you can ssh to root@<youripaddress> and it'll start the setup process.Cob wrote: Keyboard and screen are both necessary for the initial boot of the minimal image. Ssh is enabled by default, but any attempt to log in via ssh results in a message asking you to finish the set-up procedure shown above (passwords, keyboard, time-zone etc). Once that's been completed the device will automatically reboot and can then be accessed via ssh.
I've installed the latest updates,
missing is KVM and XRDP support
