1919715071
Unable to pass RNDIS ssh [email protected]
Sat Jul 20, 2019 2:16 pm
System: archlinux
Raspberrypi has been configured according to the tutorial dtoverlay=dwc2 and modules-load=dwc2,g_ether
Testing under mac can be connected to pi using ssh [email protected]
But it can't connect under archlinux. Always prompt: ssh: Could not resolve hostname raspberrypi.local: Name or service not known
When pi connects to archlinux via usb, a local connection will occur, which is configured as IPV4 for local connection, but is invalid.
The following information is output by the command sudo dmesg:
[    0.000000] Linux version 5.1.15-1-surface ([email protected]) (gcc version 9.1.0 (GCC)) #1 SMP PREEMPT Sun Jun 30 18:40:40 EDT 2019
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-linux-surface root=UUID=f6a03f22-05db-4cd6-81fe-abfc308437a4 rw quiet
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Hygon HygonGenuine
[    0.000000]   Centaur CentaurHauls
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] NX (Execute Disable) protection: active
[    0.001406]   5 disabled
[    0.001407]   6 disabled
[    0.001407]   7 disabled
[    0.001408]   8 disabled
[    0.001408]   9 disabled
[    0.002537] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.002835] last_pfn = 0x8bf00 max_arch_pfn = 0x400000000
[    0.017885] esrt: Reserving ESRT space from 0x000000008bdf6698 to 0x000000008bdf6798.
[    0.017912] check: Scanning 1 areas for low memory corruption
[    0.017916] Using GB pages for direct mapping
[    0.017918] BRK [0x122a01000, 0x122a01fff] PGTABLE
[    0.017920] BRK [0x122a02000, 0x122a02fff] PGTABLE
[    0.017921] BRK [0x122a03000, 0x122a03fff] PGTABLE
[    0.017956] BRK [0x122a04000, 0x122a04fff] PGTABLE
[    0.017958] BRK [0x122a05000, 0x122a05fff] PGTABLE
[    0.018129] BRK [0x122a06000, 0x122a06fff] PGTABLE
[    0.018174] BRK [0x122a07000, 0x122a07fff] PGTABLE
[    0.018316] BRK [0x122a08000, 0x122a08fff] PGTABLE
[    0.018379] BRK [0x122a09000, 0x122a09fff] PGTABLE
[    0.018455] Secure boot could not be determined
[    0.018456] RAMDISK: [mem 0x36e77000-0x37732fff]
[    0.018467] ACPI: Early table checksum verification disabled
[    0.018470] ACPI: RSDP 0x000000008BEFE014 000024 (v02 MSFT  )
[    0.018473] ACPI: XSDT 0x000000008BEFD0E8 0000AC (v01 MSFT   MSFT     00000000 MSFT 0000005F)
[    0.018479] ACPI: FACP 0x000000008BEF5000 00010C (v05 MSFT   MSFT     00000000 MSFT 0000005F)
[    0.018484] ACPI: DSDT 0x000000008BED8000 018587 (v02 MSFT   MSFT     00000000 INTL 20160422)
[    0.018487] ACPI: FACS 0x000000008BE66000 000040
[    0.018490] ACPI: SSDT 0x000000008BEFC000 000577 (v02 MSFT   Tpm2Tabl 00001000 INTL 20160422)
[    0.018492] ACPI: TPM2 0x000000008BEFB000 000034 (v03 MSFT   MSFT     00000002 MSFT 0000005F)
[    0.018495] ACPI: MSDM 0x000000008BEFA000 000055 (v01 MSFT            00000001 MSFT 00000001)
[    0.018498] ACPI: SSDT 0x000000008BEF6000 00312B (v02 SaSsdt SaSsdt   00003000 INTL 20160422)
[    0.018501] ACPI: HPET 0x000000008BEF4000 000038 (v01 MSFT   MSFT     00000001 MSFT 0000005F)
[    0.018503] ACPI: APIC 0x000000008BEF3000 00012C (v03 MSFT   MSFT     00000001 MSFT 0000005F)
[    0.018506] ACPI: MCFG 0x000000008BEF2000 00003C (v01 MSFT   MSFT     00000001 MSFT 0000005F)
[    0.018509] ACPI: LPIT 0x000000008BEF1000 000094 (v01 MSFT   MSFT     00000000 MSFT 0000005F)
[    0.018511] ACPI: SSDT 0x000000008BED5000 00249A (v02 MSFT   RTD3_CH  00001000 INTL 20160422)
[    0.018514] ACPI: SSDT 0x000000008BED4000 00075B (v02 MSFT   xh_ch000 00000000 INTL 20160422)
[    0.018516] ACPI: SSDT 0x000000008BED2000 0017AE (v02 CpuRef CpuSsdt  00003000 INTL 20160422)
[    0.018519] ACPI: DMAR 0x000000008BED1000 000114 (v01 MSFT   MSFT     00000001 INTL 00000001)
[    0.018522] ACPI: NHLT 0x000000008BED0000 00002D (v00 MSFT   MSFT     00000002 MSFT 0000005F)
[    0.018524] ACPI: FPDT 0x000000008BECF000 000034 (v01 MSFT   MSFT     00000002 MSFT 0000005F)
[    0.018527] ACPI: BGRT 0x000000008BECE000 000038 (v01 MSFT   MSFT     00000002 MSFT 0000005F)
[    0.018530] ACPI: WSMT 0x000000008BECD000 000028 (v01 MSFT   MSFT     00000002 MSFT 0000005F)
[    0.018539] ACPI: Local APIC address 0xfee00000
[    0.018742] No NUMA configuration found
[    0.018743] Faking a node at [mem 0x0000000000000000-0x000000026f7fffff]
[    0.018747] NODE_DATA(0) allocated [mem 0x26f7fd000-0x26f7fffff]
[    0.018767] Zone ranges:
[    0.018768]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.018769]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.018770]   Normal   [mem 0x0000000100000000-0x000000026f7fffff]
[    0.018771]   Device   empty
[    0.018772] Movable zone start for each node
[    0.018772] Early memory node ranges
[    0.018773]   node   0: [mem 0x0000000000001000-0x0000000000057fff]
[    0.018774]   node   0: [mem 0x0000000000059000-0x000000000009dfff]
[    0.018775]   node   0: [mem 0x0000000000100000-0x000000008aa24fff]
[    0.018775]   node   0: [mem 0x000000008aa27000-0x000000008bcccfff]
[    0.018776]   node   0: [mem 0x000000008beff000-0x000000008befffff]
[    0.018777]   node   0: [mem 0x0000000100000000-0x000000026f7fffff]
[    0.019050] Zeroed struct page in unavailable ranges: 17304 pages
[    0.019051] Initmem setup node 0 [mem 0x0000000000001000-0x000000026f7fffff]
[    0.019053] On node 0 totalpages: 2077800
[    0.019054]   DMA zone: 64 pages used for memmap
[    0.019055]   DMA zone: 23 pages reserved
[    0.019055]   DMA zone: 3996 pages, LIFO batch:0
[    0.019150]   DMA32 zone: 8884 pages used for memmap
[    0.019151]   DMA32 zone: 568524 pages, LIFO batch:63
[    0.033838]   Normal zone: 23520 pages used for memmap
[    0.033838]   Normal zone: 1505280 pages, LIFO batch:63
[    0.068678] Reserving Intel graphics memory at [mem 0x8d800000-0x8f7fffff]
[    0.068997] ACPI: PM-Timer IO Port: 0x1808
[    0.068999] ACPI: Local APIC address 0xfee00000
[    0.069005] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.069006] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.069007] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.069007] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.069008] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.069009] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.069009] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.069010] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.069010] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.069011] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.069012] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.069012] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.069013] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.069013] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.069014] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.069015] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.069044] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.069046] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.069048] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.069049] ACPI: IRQ0 used by override.
[    0.069050] ACPI: IRQ9 used by override.
[    0.069052] Using ACPI (MADT) for SMP configuration information
[    0.069054] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.069065] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.069082] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.069083] PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.069085] PM: Registered nosave memory: [mem 0x0009e000-0x000fffff]
[    0.069086] PM: Registered nosave memory: [mem 0x8aa25000-0x8aa25fff]
[    0.069087] PM: Registered nosave memory: [mem 0x8aa26000-0x8aa26fff]
[    0.069088] PM: Registered nosave memory: [mem 0x8bccd000-0x8bd47fff]
[    0.069089] PM: Registered nosave memory: [mem 0x8bd48000-0x8be5ffff]
[    0.069089] PM: Registered nosave memory: [mem 0x8be60000-0x8be85fff]
[    0.069090] PM: Registered nosave memory: [mem 0x8be86000-0x8befefff]
[    0.069091] PM: Registered nosave memory: [mem 0x8bf00000-0x8f7fffff]
[    0.069092] PM: Registered nosave memory: [mem 0x8f800000-0xdfffffff]
[    0.069093] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.069093] PM: Registered nosave memory: [mem 0xf0000000-0xfe00ffff]
[    0.069094] PM: Registered nosave memory: [mem 0xfe010000-0xfe010fff]
[    0.069094] PM: Registered nosave memory: [mem 0xfe011000-0xffffffff]
[    0.069096] [mem 0x8f800000-0xdfffffff] available for PCI devices
[    0.069097] Booting paravirtualized kernel on bare hardware
[    0.069100] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.176483] random: get_random_bytes called from start_kernel+0x8d/0x52b with crng_init=0
[    0.176490] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[    0.176648] percpu: Embedded 45 pages/cpu s147456 r8192 d28672 u524288
[    0.176656] pcpu-alloc: s147456 r8192 d28672 u524288 alloc=1*2097152
[    0.176657] pcpu-alloc: [0] 0 1 2 3
[    0.176675] Built 1 zonelists, mobility grouping on.  Total pages: 2045309
[    0.176676] Policy zone: Normal
[    0.176678] Kernel command line: BOOT_IMAGE=/vmlinuz-linux-surface root=UUID=f6a03f22-05db-4cd6-81fe-abfc308437a4 rw quiet
[    0.180069] Calgary: detecting Calgary via BIOS EBDA area
[    0.180071] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.197424] Memory: 7974908K/8311200K available (10243K kernel code, 1233K rwdata, 3364K rodata, 1500K init, 4248K bss, 336292K reserved, 0K cma-reserved)
[    0.197571] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.197572] Kernel/User page tables isolation: enabled
[    0.197586] ftrace: allocating 33644 entries in 132 pages
[    0.211982] rcu: Preemptible hierarchical RCU implementation.
[    0.211983] rcu: 	CONFIG_RCU_FANOUT set to non-default value of 32.
[    0.211984] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.211985] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[    0.211985] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.211986] 	Tasks RCU enabled.
[    0.211987] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.211988] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.213546] NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
[    0.213759] rcu: 	Offload RCU callbacks from CPUs: (none).
[    0.213879] Console: colour dummy device 80x25
[    0.213882] printk: console [tty0] enabled
[    0.213899] ACPI: Core revision 20190215
[    0.214244] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[    0.214276] hpet clockevent registered
[    0.214323] APIC: Switch to symmetric I/O mode setup
[    0.214325] DMAR: Host address width 39
[    0.214326] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.214333] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 7e3ff0505e
[    0.214334] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.214337] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.214338] DMAR: RMRR base: 0x0000003e2e0000 end: 0x0000003e2fffff
[    0.214339] DMAR: RMRR base: 0x0000008d000000 end: 0x0000008f7fffff
[    0.214340] DMAR: ANDD device: 1 name: \_SB.PCI0.I2C0
[    0.214341] DMAR: ANDD device: 2 name: \_SB.PCI0.I2C1
[    0.214341] DMAR: ANDD device: 4 name: \_SB.PCI0.I2C3
[    0.214343] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.214344] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.214345] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.215938] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.215939] x2apic enabled
[    0.215954] Switched APIC routing to cluster x2apic.
[    0.220118] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.224290] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x23fa772cf26, max_idle_ns: 440795269835 ns
[    0.224303] Calibrating delay loop (skipped), value calculated using timer frequency.. 4992.00 BogoMIPS (lpj=2496000)
[    0.224305] pid_max: default: 32768 minimum: 301
[    0.228471] LSM: Security Framework initializing
[    0.228475] Yama: becoming mindful.
[    0.229562] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.230099] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.230124] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.230141] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.230299] *** VALIDATE proc ***
[    0.230354] *** VALIDATE cgroup1 ***
[    0.230355] *** VALIDATE cgroup2 ***
[    0.230385] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.230386] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.230400] mce: CPU0: Thermal monitoring enabled (TM1)
[    0.230415] process: using mwait in idle threads
[    0.230417] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.230418] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.230419] Spectre V2 : Mitigation: Full generic retpoline
[    0.230420] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.230420] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.230426] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.230427] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.230428] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.230454] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[    0.230723] Freeing SMP alternatives memory: 28K
[    0.232139] TSC deadline timer enabled
[    0.232143] smpboot: CPU0: Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz (family: 0x6, model: 0x4e, stepping: 0x3)
[    0.237335] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.237367] ... version:                4
[    0.237368] ... bit width:              48
[    0.237368] ... generic registers:      4
[    0.237369] ... value mask:             0000ffffffffffff
[    0.237369] ... max period:             00007fffffffffff
[    0.237370] ... fixed-purpose events:   3
[    0.237370] ... event mask:             000000070000000f
[    0.239308] rcu: Hierarchical SRCU implementation.
[    0.244429] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.246337] smp: Bringing up secondary CPUs ...
[    0.256341] x86: Booting SMP configuration:
[    0.256342] .... node  #0, CPUs:      #1 #2
[    0.266776] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.276341]  #3
[    0.276727] smp: Brought up 1 node, 4 CPUs
[    0.276727] smpboot: Max logical packages: 1
[    0.276727] smpboot: Total of 4 processors activated (19968.00 BogoMIPS)
[    0.277546] devtmpfs: initialized
[    0.277546] x86/mm: Memory block size: 128MB
[    0.278311] PM: Registering ACPI NVS region [mem 0x8aa25000-0x8aa25fff] (4096 bytes)
[    0.278311] PM: Registering ACPI NVS region [mem 0x8be60000-0x8be85fff] (155648 bytes)
[    0.278364] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.278364] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.278364] pinctrl core: initialized pinctrl subsystem
[    0.278532] PM: RTC time: 06:57:18, date: 2019-07-19
[    0.278656] NET: Registered protocol family 16
[    0.278804] cpuidle: using governor ladder
[    0.278807] cpuidle: using governor menu
[    0.278822] ACPI: bus type PCI registered
[    0.278822] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.278822] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.278822] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.278822] PCI: Using configuration type 1 for base access
[    0.279915] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.279915] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.279915] ACPI: Added _OSI(Module Device)
[    0.279915] ACPI: Added _OSI(Processor Device)
[    0.279915] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.279915] ACPI: Added _OSI(Processor Aggregator Device)
[    0.279915] ACPI: Added _OSI(Linux-Dell-Video)
[    0.279915] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.279915] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.314784] ACPI: 6 ACPI AML tables successfully acquired and loaded
[    0.318083] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.322693] ACPI: Dynamic OEM Table Load:
[    0.322707] ACPI: SSDT 0xFFFFA13865A16000 000672 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.323342] ACPI: \_PR_.PR00: _OSC native thermal LVT Acked
[    0.324424] ACPI: Dynamic OEM Table Load:
[    0.324429] ACPI: SSDT 0xFFFFA138654D4000 0003FF (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.325453] ACPI: Dynamic OEM Table Load:
[    0.325461] ACPI: SSDT 0xFFFFA138654DD000 000D14 (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.326837] ACPI: Dynamic OEM Table Load:
[    0.326842] ACPI: SSDT 0xFFFFA138654D5C00 00030A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.328756] ACPI: EC: EC started
[    0.328756] ACPI: EC: interrupt blocked
[    0.331837] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
[    0.331840] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x50, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.331841] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[    0.331842] ACPI: Interpreter enabled
[    0.331891] ACPI: (supports S0 S4 S5)
[    0.331892] ACPI: Using IOAPIC for interrupt routing
[    0.331936] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.332588] ACPI: Enabled 10 GPEs in block 00 to 7F
[    0.338777] ACPI: Power Resource [PX01] (on)
[    0.338861] ACPI: Power Resource [PX02] (on)
[    0.338944] ACPI: Power Resource [PX03] (on)
[    0.339024] ACPI: Power Resource [PX04] (on)
[    0.340425] ACPI: Power Resource [USBC] (on)
[    0.340652] ACPI: Power Resource [PAUD] (on)
[    0.342896] ACPI: Power Resource [PRP5] (on)
[    0.344998] ACPI: Power Resource [PXP] (off)
[    0.347187] ACPI: Power Resource [PXP] (off)
[    0.347465] ACPI: Power Resource [PRWF] (on)
[    0.356010] ACPI: Power Resource [CAMP] (on)
[    0.361934] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.361940] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig Segments MSI]
[    0.362038] acpi PNP0A08:00: PCIe port services disabled; not requesting _OSC control
[    0.364532] PCI host bridge to bus 0000:00
[    0.364534] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.364536] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.364537] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.364538] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[    0.364538] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[    0.364539] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[    0.364540] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
[    0.364541] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.364542] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.364543] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.364544] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.364545] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[    0.364545] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[    0.364546] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[    0.364547] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[    0.364548] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[    0.364549] pci_bus 0000:00: root bus resource [mem 0x8f800000-0xdfffffff window]
[    0.364550] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[    0.364551] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.364560] pci 0000:00:00.0: [8086:1904] type 00 class 0x060000
[    0.365505] pci 0000:00:02.0: [8086:1916] type 00 class 0x030000
[    0.365516] pci 0000:00:02.0: reg 0x10: [mem 0xa0000000-0xa0ffffff 64bit]
[    0.365522] pci 0000:00:02.0: reg 0x18: [mem 0x90000000-0x9fffffff 64bit pref]
[    0.365526] pci 0000:00:02.0: reg 0x20: [io  0x4000-0x403f]
[    0.365541] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.366494] pci 0000:00:05.0: [8086:1919] type 00 class 0x048000
[    0.366506] pci 0000:00:05.0: reg 0x10: [mem 0xa1000000-0xa13fffff 64bit]
[    0.367456] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[    0.367468] pci 0000:00:08.0: reg 0x10: [mem 0xa1738000-0xa1738fff 64bit]
[    0.368426] pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330
[    0.368448] pci 0000:00:14.0: reg 0x10: [mem 0xa1700000-0xa170ffff 64bit]
[    0.368514] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.369533] pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000
[    0.369556] pci 0000:00:14.2: reg 0x10: [mem 0xa1739000-0xa1739fff 64bit]
[    0.370557] pci 0000:00:14.3: [8086:9d32] type 00 class 0x048000
[    0.370668] pci 0000:00:14.3: reg 0x10: [mem 0xa1710000-0xa171ffff 64bit]
[    0.372015] pci 0000:00:15.0: [8086:9d60] type 00 class 0x118000
[    0.372229] pci 0000:00:15.0: reg 0x10: [mem 0xa173a000-0xa173afff 64bit]
[    0.373902] pci 0000:00:15.1: [8086:9d61] type 00 class 0x118000
[    0.374016] pci 0000:00:15.1: reg 0x10: [mem 0xa173b000-0xa173bfff 64bit]
[    0.375669] pci 0000:00:15.3: [8086:9d63] type 00 class 0x118000
[    0.375895] pci 0000:00:15.3: reg 0x10: [mem 0xa173c000-0xa173cfff 64bit]
[    0.377628] pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000
[    0.377652] pci 0000:00:16.0: reg 0x10: [mem 0xa173d000-0xa173dfff 64bit]
[    0.377725] pci 0000:00:16.0: PME# supported from D3hot
[    0.378716] pci 0000:00:16.4: [8086:9d3e] type 00 class 0x078000
[    0.378742] pci 0000:00:16.4: reg 0x10: [mem 0xa173e000-0xa173efff 64bit]
[    0.378810] pci 0000:00:16.4: PME# supported from D3hot
[    0.379746] pci 0000:00:1d.0: [8086:9d18] type 01 class 0x060400
[    0.379836] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.380840] pci 0000:00:1d.3: [8086:9d1b] type 01 class 0x060400
[    0.380927] pci 0000:00:1d.3: PME# supported from D0 D3hot D3cold
[    0.381945] pci 0000:00:1f.0: [8086:9d48] type 00 class 0x060100
[    0.383004] pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000
[    0.383018] pci 0000:00:1f.2: reg 0x10: [mem 0xa1734000-0xa1737fff]
[    0.384005] pci 0000:00:1f.3: [8086:9d70] type 00 class 0x040380
[    0.384031] pci 0000:00:1f.3: reg 0x10: [mem 0xa1730000-0xa1733fff 64bit]
[    0.384057] pci 0000:00:1f.3: reg 0x20: [mem 0xa1720000-0xa172ffff 64bit]
[    0.384107] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.385260] pci 0000:01:00.0: [144d:a802] type 00 class 0x010802
[    0.385289] pci 0000:01:00.0: reg 0x10: [mem 0xa1600000-0xa1603fff 64bit]
[    0.385298] pci 0000:01:00.0: reg 0x18: [io  0x3000-0x30ff]
[    0.385432] pci 0000:01:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8 GT/s x2 link at 0000:00:1d.0 (capable of 31.504 Gb/s with 8 GT/s x4 link)
[    0.385463] pci 0000:00:1d.0: PCI bridge to [bus 01]
[    0.385466] pci 0000:00:1d.0:   bridge window [io  0x3000-0x3fff]
[    0.385469] pci 0000:00:1d.0:   bridge window [mem 0xa1600000-0xa16fffff]
[    0.385613] pci 0000:02:00.0: [11ab:2b38] type 00 class 0x020000
[    0.385657] pci 0000:02:00.0: reg 0x10: [mem 0xa1500000-0xa15fffff 64bit pref]
[    0.385675] pci 0000:02:00.0: reg 0x18: [mem 0xa1400000-0xa14fffff 64bit pref]
[    0.385815] pci 0000:02:00.0: supports D1 D2
[    0.385816] pci 0000:02:00.0: PME# supported from D0 D1 D3hot D3cold
[    0.385909] pci 0000:00:1d.3: PCI bridge to [bus 02]
[    0.385916] pci 0000:00:1d.3:   bridge window [mem 0xa1400000-0xa15fffff 64bit pref]
[    0.394379] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.394459] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.394538] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.394615] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.394693] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.394772] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.394849] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.394924] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.402715] ACPI Warning: GPE type mismatch (level/edge) (20190215/evxface-791)
[    0.402718] ACPI: EC: interrupt unblocked
[    0.402736] ACPI: EC: event unblocked
[    0.402749] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x50, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.402751] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions and events
[    0.402847] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.402847] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.402847] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.402847] vgaarb: loaded
[    0.402847] pps_core: LinuxPPS API ver. 1 registered
[    0.402847] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    0.402847] PTP clock support registered
[    0.402847] EDAC MC: Ver: 3.0.0
[    0.403312] Registered efivars operations
[    0.410386] PCI: Using ACPI for IRQ routing
[    0.438742] PCI: pci_cache_line_size set to 64 bytes
[    0.439115] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.439117] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    0.439117] e820: reserve RAM buffer [mem 0x8aa25000-0x8bffffff]
[    0.439119] e820: reserve RAM buffer [mem 0x8bccd000-0x8bffffff]
[    0.439120] e820: reserve RAM buffer [mem 0x8bf00000-0x8bffffff]
[    0.439120] e820: reserve RAM buffer [mem 0x26f800000-0x26fffffff]
[    0.439293] NetLabel: Initializing
[    0.439293] NetLabel:  domain hash size = 128
[    0.439293] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.439293] NetLabel:  unlabeled traffic allowed by default
[    0.439337] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.439337] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    0.442312] clocksource: Switched to clocksource tsc-early
[    0.452752] VFS: Disk quotas dquot_6.6.0
[    0.452767] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.452792] *** VALIDATE hugetlbfs ***
[    0.452838] pnp: PnP ACPI init
[    0.453045] system 00:00: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.453046] system 00:00: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.453047] system 00:00: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.453049] system 00:00: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.453050] system 00:00: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.453051] system 00:00: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.453052] system 00:00: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.453056] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.453429] system 00:01: [io  0x2000-0x20fe] has been reserved
[    0.453432] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.455885] system 00:02: [io  0x0680-0x069f] has been reserved
[    0.455886] system 00:02: [io  0xffff] has been reserved
[    0.455887] system 00:02: [io  0xffff] has been reserved
[    0.455888] system 00:02: [io  0xffff] has been reserved
[    0.455889] system 00:02: [io  0x1800-0x18fe] has been reserved
[    0.455890] system 00:02: [io  0x164e-0x164f] has been reserved
[    0.455894] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.456003] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.456046] system 00:04: [io  0x1854-0x1857] has been reserved
[    0.456049] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.457877] system 00:05: [mem 0xfe020000-0xfe021fff] has been reserved
[    0.457879] system 00:05: [mem 0xfe022000-0xfe023fff] has been reserved
[    0.457880] system 00:05: [mem 0xfe024000-0xfe025fff] has been reserved
[    0.457881] system 00:05: [mem 0xfe026000-0xfe027fff] has been reserved
[    0.457882] system 00:05: [mem 0xfe028000-0xfe029fff] has been reserved
[    0.457884] system 00:05: [mem 0xfe02a000-0xfe02bfff] has been reserved
[    0.457885] system 00:05: [mem 0xfe02c000-0xfe02dfff] has been reserved
[    0.457886] system 00:05: [mem 0xfe02e000-0xfe02ffff] has been reserved
[    0.457887] system 00:05: [mem 0xfe030000-0xfe031fff] has been reserved
[    0.457888] system 00:05: [mem 0xfe032000-0xfe033fff] has been reserved
[    0.457889] system 00:05: [mem 0xfe034000-0xfe035fff] has been reserved
[    0.457893] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.458533] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.458536] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.458537] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.458539] system 00:06: [mem 0xe0000000-0xefffffff] has been reserved
[    0.458540] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.458541] system 00:06: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.458542] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.458543] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[    0.458545] system 00:06: [mem 0xfee00000-0xfeefffff] has been reserved
[    0.458546] system 00:06: [mem 0x8f800000-0x8f81ffff] has been reserved
[    0.458549] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.459242] pnp: PnP ACPI: found 7 devices
[    0.464923] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.464943] pci 0000:00:1d.0: PCI bridge to [bus 01]
[    0.464949] pci 0000:00:1d.0:   bridge window [io  0x3000-0x3fff]
[    0.464958] pci 0000:00:1d.0:   bridge window [mem 0xa1600000-0xa16fffff]
[    0.464968] pci 0000:00:1d.3: PCI bridge to [bus 02]
[    0.464977] pci 0000:00:1d.3:   bridge window [mem 0xa1400000-0xa15fffff 64bit pref]
[    0.464985] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.464987] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.464990] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.464992] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[    0.464994] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[    0.464997] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[    0.464999] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
[    0.465001] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
[    0.465003] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
[    0.465006] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
[    0.465008] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
[    0.465010] pci_bus 0000:00: resource 15 [mem 0x000e0000-0x000e3fff window]
[    0.465013] pci_bus 0000:00: resource 16 [mem 0x000e4000-0x000e7fff window]
[    0.465015] pci_bus 0000:00: resource 17 [mem 0x000e8000-0x000ebfff window]
[    0.465018] pci_bus 0000:00: resource 18 [mem 0x000ec000-0x000effff window]
[    0.465020] pci_bus 0000:00: resource 19 [mem 0x000f0000-0x000fffff window]
[    0.465022] pci_bus 0000:00: resource 20 [mem 0x8f800000-0xdfffffff window]
[    0.465025] pci_bus 0000:00: resource 21 [mem 0xfd000000-0xfe7fffff window]
[    0.465027] pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
[    0.465030] pci_bus 0000:01: resource 1 [mem 0xa1600000-0xa16fffff]
[    0.465032] pci_bus 0000:02: resource 2 [mem 0xa1400000-0xa15fffff 64bit pref]
[    0.465378] NET: Registered protocol family 2
[    0.467375] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes)
[    0.467405] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.467513] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.467610] TCP: Hash tables configured (established 65536 bind 65536)
[    0.467646] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    0.467666] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    0.467718] NET: Registered protocol family 1
[    0.467731] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.468257] PCI: CLS 0 bytes, default 64
[    0.468289] Unpacking initramfs...
[    0.604345] Freeing initrd memory: 8944K
[    0.604380] DMAR: ACPI device "device:71" under DMAR at fed91000 as 00:15.0
[    0.604383] DMAR: ACPI device "device:72" under DMAR at fed91000 as 00:15.1
[    0.604385] DMAR: ACPI device "device:73" under DMAR at fed91000 as 00:15.3
[    0.615353] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.615354] software IO TLB: mapped [mem 0x80bcc000-0x84bcc000] (64MB)
[    0.615377] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x23fa772cf26, max_idle_ns: 440795269835 ns
[    0.615388] clocksource: Switched to clocksource tsc
[    0.615472] check: Scanning for low memory corruption every 60 seconds
[    0.616029] Initialise system trusted keyrings
[    0.616036] Key type blacklist registered
[    0.616077] workingset: timestamp_bits=44 max_order=21 bucket_order=0
[    0.617333] zbud: loaded
[    0.658589] Key type asymmetric registered
[    0.658591] Asymmetric key parser 'x509' registered
[    0.658606] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.658648] io scheduler mq-deadline registered
[    0.658649] io scheduler kyber registered
[    0.658706] io scheduler bfq registered
[    0.658885] efifb: probing for efifb
[    0.658902] efifb: framebuffer at 0x90000000, using 23552k, total 23552k
[    0.658903] efifb: mode is 3000x2000x32, linelength=12032, pages=1
[    0.658903] efifb: scrolling: redraw
[    0.658904] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.659004] Console: switching to colour frame buffer device 375x125
[    0.670360] fb0: EFI VGA frame buffer device
[    0.670369] intel_idle: MWAIT substates: 0x11142120
[    0.670370] intel_idle: v0.4.1 model 0x4E
[    0.670574] intel_idle: lapic_timer_reliable_states 0xffffffff
[    0.670688] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[    0.670696] ACPI: Lid Switch [LID0]
[    0.683380] thermal LNXTHERM:00: registered as thermal_zone0
[    0.683382] ACPI: Thermal Zone [TZ00] (40 C)
[    0.704058] thermal LNXTHERM:01: registered as thermal_zone1
[    0.704059] ACPI: Thermal Zone [TZ01] (0 C)
[    0.719291] thermal LNXTHERM:02: registered as thermal_zone2
[    0.719299] ACPI: Thermal Zone [TZ02] (29 C)
[    0.732033] thermal LNXTHERM:03: registered as thermal_zone3
[    0.732035] ACPI: Thermal Zone [TZ03] (30 C)
[    0.744159] thermal LNXTHERM:04: registered as thermal_zone4
[    0.744161] ACPI: Thermal Zone [TZ04] (0 C)
[    0.759146] thermal LNXTHERM:05: registered as thermal_zone5
[    0.759148] ACPI: Thermal Zone [TZ05] (0 C)
[    0.772491] thermal LNXTHERM:06: registered as thermal_zone6
[    0.772493] ACPI: Thermal Zone [TZ06] (30 C)
[    0.772943] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.774513] nvme nvme0: pci function 0000:01:00.0
[    0.774588] intel_pstate: Intel P-state driver initializing
[    0.774755] intel_pstate: HWP enabled
[    0.774957] ledtrig-cpu: registered to indicate activity on CPUs
[    0.775000] intel_pmc_core:  initialized
[    0.775176] NET: Registered protocol family 10
[    0.782153] Segment Routing with IPv6
[    0.782181] NET: Registered protocol family 17
[    0.782430] mce: Using 8 MCE banks
[    0.782445] RAS: Correctable Errors collector initialized.
[    0.782476] microcode: sig=0x406e3, pf=0x80, revision=0xc6
[    0.782586] microcode: Microcode Update Driver: v2.2.
[    0.782596] sched_clock: Marking stable (783145337, -564833)->(787991197, -5410693)
[    0.782753] registered taskstats version 1
[    0.782761] Loading compiled-in X.509 certificates
[    0.782776] zswap: loaded using pool lzo/zbud
[    0.788321] Key type big_key registered
[    0.789141] PM:   Magic number: 11:510:974
[    0.789192] hctosys: unable to open rtc device (rtc0)
[    0.880172] nvme nvme0: 4/0/0 default/read/poll queues
[    0.884012]  nvme0n1: p1 p2 p3 p4
[    0.886139] Freeing unused decrypted memory: 2040K
[    0.886462] Freeing unused kernel image memory: 1500K
[    0.892500] Write protecting the kernel read-only data: 16384k
[    0.893535] Freeing unused kernel image memory: 2020K
[    0.893921] Freeing unused kernel image memory: 732K
[    0.893982] Run /init as init process
[    0.973830] ACPI: bus type USB registered
[    0.973851] usbcore: registered new interface driver usbfs
[    0.973860] usbcore: registered new interface driver hub
[    0.973886] usbcore: registered new device driver usb
[    0.977807] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.977814] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    0.978882] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
[    0.978887] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    0.979180] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.01
[    0.979182] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.979184] usb usb1: Product: xHCI Host Controller
[    0.979216] usb usb1: Manufacturer: Linux 5.1.15-1-surface xhci-hcd
[    0.979217] usb usb1: SerialNumber: 0000:00:14.0
[    0.979381] hub 1-0:1.0: USB hub found
[    0.979398] hub 1-0:1.0: 12 ports detected
[    0.981616] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.981620] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    0.981623] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    0.981662] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.01
[    0.981664] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.981665] usb usb2: Product: xHCI Host Controller
[    0.981666] usb usb2: Manufacturer: Linux 5.1.15-1-surface xhci-hcd
[    0.981667] usb usb2: SerialNumber: 0000:00:14.0
[    0.981774] hub 2-0:1.0: USB hub found
[    0.981786] hub 2-0:1.0: 6 ports detected
[    0.987674] random: fast init done
[    1.040346] EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
[    1.153439] systemd[1]: systemd 242.32-3-arch running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    1.165487] systemd[1]: Detected architecture x86-64.
[    1.171455] systemd[1]: Set hostname to <liwt>.
[    1.266610] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    1.266894] systemd[1]: Listening on LVM2 metadata daemon socket.
[    1.266952] systemd[1]: Listening on udev Kernel Socket.
[    1.267019] systemd[1]: Listening on Journal Socket.
[    1.268724] systemd[1]: Starting Load Kernel Modules...
[    1.269351] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    1.269461] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    1.282330] random: lvm: uninitialized urandom read (4 bytes read)
[    1.295566] EXT4-fs (nvme0n1p3): re-mounted. Opts: (null)
[    1.304444] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[    1.309546] random: systemd-random-: uninitialized urandom read (512 bytes read)
[    1.319719] usb 2-1: New USB device found, idVendor=045e, idProduct=090b, bcdDevice=47.11
[    1.319721] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.319722] usb 2-1: Product: USB3.0 Hub
[    1.319723] usb 2-1: Manufacturer: Microsoft
[    1.322859] hub 2-1:1.0: USB hub found
[    1.323116] hub 2-1:1.0: 3 ports detected
[    1.433300] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.529839] systemd-journald[232]: Received request to flush runtime journal from PID 1
[    1.573590] usb 1-1: New USB device found, idVendor=045e, idProduct=091a, bcdDevice=47.11
[    1.573592] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.573593] usb 1-1: Product: USB2.0 Hub
[    1.573593] usb 1-1: Manufacturer: Microsoft
[    1.575020] hub 1-1:1.0: USB hub found
[    1.576413] hub 1-1:1.0: 4 ports detected
[    1.629976] usb 2-1.3: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[    1.669150] usb 2-1.3: New USB device found, idVendor=045e, idProduct=090c, bcdDevice=29.10
[    1.669153] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.669154] usb 2-1.3: Product: SD Card
[    1.669156] usb 2-1.3: Manufacturer: Microsoft
[    1.669157] usb 2-1.3: SerialNumber: 201408282030
[    1.671340] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    1.679939] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    1.680257] media: Linux media interface: v0.10
[    1.694639] Linux agpgart interface v0.103
[    1.705539] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    1.705885] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    1.709372] tpm_tis NTZ0401:00: 2.0 TPM (device-id 0x101, rev-id 1)
[    1.719744] intel-lpss 0000:00:15.3: enabling device (0000 -> 0002)
[    1.720088] idma64 idma64.2: Found Intel integrated DMA 64-bit
[    1.727110] mei_me 0000:00:16.0: enabling device (0004 -> 0006)
[    1.727384] mei_me 0000:00:16.4: enabling device (0004 -> 0006)
[    1.751394] videodev: Linux video capture interface: v2.00
[    1.751707] rtc_cmos 00:03: RTC can wake from S4
[    1.752643] rtc_cmos 00:03: registered as rtc0
[    1.752671] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram
[    1.765885] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.780629] ACPI: AC Adapter [ADP1] (on-line)
[    1.781610] input: PC Speaker as /devices/platform/pcspkr/input/input1
[    1.784264] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.785107] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.785110] cfg80211: failed to load regulatory.db
[    1.799267] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[    1.799269] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    1.799270] RAPL PMU: hw unit of domain package 2^-14 Joules
[    1.799270] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    1.799271] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    1.799272] RAPL PMU: hw unit of domain psys 2^-14 Joules
[    1.807493] input: Surface Pro 3/4 Buttons as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:19/PNP0C09:00/MSHW0040:00/input/input2
[    1.807839] surface_pro3_button MSHW0040:00: Surface Pro 3/4 Buttons [VGBI]
[    1.809272] hidraw: raw HID events driver (C) Jiri Kosina
[    1.823003] ipu3-cio2 0000:00:14.3: enabling device (0000 -> 0002)
[    1.823187] ipu3-cio2 0000:00:14.3: device 0x9d32 (rev: 0x1)
[    1.827326] ipu3-cio2 0000:00:14.3: Entity type for entity ipu3-csi2 0 was not initialized!
[    1.828061] ipu3-cio2 0000:00:14.3: Entity type for entity ipu3-csi2 1 was not initialized!
[    1.828571] ipu3-cio2 0000:00:14.3: Entity type for entity ipu3-csi2 2 was not initialized!
[    1.829133] ipu3-cio2 0000:00:14.3: Entity type for entity ipu3-csi2 3 was not initialized!
[    1.834703] cryptd: max_cpu_qlen set to 1000
[    1.865726] AVX2 version of gcm_enc/dec engaged.
[    1.865728] AES CTR mode by8 optimization enabled
[    1.872153] battery: ACPI: Battery Slot [BAT1] (battery present)
[    1.874440] Adding 3834156k swap on /dev/nvme0n1p4.  Priority:-2 extents:1 across:3834156k SSFS
[    1.876317] usb 1-1.1: new high-speed USB device number 3 using xhci_hcd
[    1.937218] mwifiex_pcie 0000:02:00.0: enabling device (0000 -> 0002)
[    1.941109] mwifiex_pcie: try set_consistent_dma_mask(32)
[    1.941150] mwifiex_pcie: PCI memory map Virt0: 000000003ced192b PCI memory map Virt2: 000000005a9af35e
[    1.945621] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    1.956014] usb 1-1.1: New USB device found, idVendor=0525, idProduct=a4a2, bcdDevice= 4.19
[    1.956017] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.956019] usb 1-1.1: Product: RNDIS/Ethernet Gadget
[    1.956020] usb 1-1.1: Manufacturer: Linux 4.19.57+ with 20980000.usb
[    1.957445] i2c_hid i2c-MSHW0030:00: i2c-MSHW0030:00 supply vdd not found, using dummy regulator
[    1.957461] i2c_hid i2c-MSHW0030:00: i2c-MSHW0030:00 supply vddl not found, using dummy regulator
[    1.979030] battery: ACPI: Battery Slot [BAT2] (battery present)
[    2.008422] random: crng init done
[    2.027308] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
[    2.049934] hid-generic 0018:045E:0914.0001: hidraw0: I2C HID v1.00 Device [MSHW0030:00 045E:0914] on i2c-MSHW0030:00
[    2.108497] usb 1-1.4: New USB device found, idVendor=045e, idProduct=07cd, bcdDevice= 5.07
[    2.108499] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.108501] usb 1-1.4: Product: Surface Keyboard
[    2.108502] usb 1-1.4: Manufacturer: Microsoft
[    2.145290] checking generic (90000000 1700000) vs hw (90000000 10000000)
[    2.145297] fb0: switching to inteldrmfb from EFI VGA
[    2.145314] Console: switching to colour dummy device 80x25
[    2.147381] i915 0000:00:02.0: vgaarb: deactivate vga console
[    2.151864] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.151866] [drm] Driver supports precise vblank timestamp query.
[    2.154090] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    2.158178] [drm] Finished loading DMC firmware i915/skl_dmc_ver1_27.bin (v1.27)
[    2.183348] [drm] HuC: Loaded firmware i915/skl_huc_ver01_07_1398.bin (version 1.7)
[    2.194325] [drm] GuC: Loaded firmware i915/skl_guc_ver9_33.bin (version 9.33)
[    2.205648] i915 0000:00:02.0: GuC firmware version 9.33
[    2.205650] i915 0000:00:02.0: GuC submission enabled
[    2.205651] i915 0000:00:02.0: HuC enabled
[    2.206445] ipts: initializing ipts
[    2.206626] ipts: Intel iTouch framework initialized
[    2.207673] [drm] Initialized i915 1.6.0 20190207 for 0000:00:02.0 on minor 0
[    2.211342] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    2.211856] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3
[    2.212118] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    2.244303] IPTS ipts_mei_cl_init() is called
[    2.244319] probing Intel Precise Touch & Stylus
[    2.244320] IPTS using DMA_BIT_MASK(64)
[    2.252402] ipts mei::3e8d0870-271a-4208-8eb5-9acb9402ae04:0F: Direct firmware load for intel/ipts/intel_desc.bin failed with error -2
[    2.252405] ipts mei::3e8d0870-271a-4208-8eb5-9acb9402ae04:0F: can't add hid device: -5
[    2.252414] ipts mei::3e8d0870-271a-4208-8eb5-9acb9402ae04:0F: error in handling resp msg
[    2.252632] fbcon: inteldrmfb (fb0) is primary device
[    2.285145] Console: switching to colour frame buffer device 240x67
[    2.307875] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    2.382586] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC298: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[    2.382588] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    2.382590] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    2.382591] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    2.382593] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    2.382594] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x18
[    2.382596] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[    2.470038] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input4
[    2.470089] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input5
[    2.470141] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input6
[    2.470188] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input7
[    2.470231] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input8
[    2.470273] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input9
[    2.470326] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
[    2.581564] intel_rapl: Found RAPL domain package
[    2.581566] intel_rapl: Found RAPL domain core
[    2.581567] intel_rapl: Found RAPL domain uncore
[    2.581568] intel_rapl: Found RAPL domain dram
[    3.309298] mwifiex_pcie 0000:02:00.0: info: FW download over, size 723540 bytes
[    3.748006] SCSI subsystem initialized
[    3.924710] usb-storage 2-1.3:1.0: USB Mass Storage device detected
[    3.924855] scsi host0: usb-storage 2-1.3:1.0
[    3.924970] usbcore: registered new interface driver usb-storage
[    3.927142] usbcore: registered new interface driver uas
[    4.019345] usb 1-6: new high-speed USB device number 5 using xhci_hcd
[    4.146312] usb 1-6: New USB device found, idVendor=1286, idProduct=204c, bcdDevice=32.01
[    4.146314] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.146316] usb 1-6: Product: Bluetooth and Wireless LAN Composite Device
[    4.146316] usb 1-6: Manufacturer: Marvell
[    4.146317] usb 1-6: SerialNumber: 0000000000000000
[    4.211562] input: Microsoft Surface Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input11
[    4.263770] input: Microsoft Surface Keyboard Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input12
[    4.263929] input: Microsoft Surface Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input13
[    4.264044] input: Microsoft Surface Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input14
[    4.264143] input: Microsoft Surface Keyboard Touchpad as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input15
[    4.264205] input: Microsoft Surface Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input16
[    4.264269] input: Microsoft Surface Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input17
[    4.264373] input: Microsoft Surface Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input18
[    4.264580] hid-generic 0003:045E:07CD.0002: input,hiddev0,hidraw0: USB HID v1.11 Keyboard [Microsoft Surface Keyboard] on usb-0000:00:14.0-1.4/input0
[    4.264644] usbcore: registered new interface driver usbhid
[    4.264645] usbhid: USB HID core driver
[    4.275245] cdc_subset: probe of 1-1.1:1.0 failed with error -22
[    4.277702] cdc_subset 1-1.1:1.1 usb0: register 'cdc_subset' at usb-0000:00:14.0-1.1, Linux Device, 72:81:8b:bd:b5:bd
[    4.277802] usbcore: registered new interface driver cdc_subset
[    4.277834] cdc_ether: probe of 1-1.1:1.0 failed with error -16
[    4.277936] usbcore: registered new interface driver cdc_ether
[    4.282471] cdc_subset 1-1.1:1.1 enp0s20f0u1u1i1: renamed from usb0
[    4.348382] input: Microsoft Surface Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input20
[    4.349472] mwifiex_pcie 0000:02:00.0: WLAN FW is active
[    4.400562] input: Microsoft Surface Keyboard Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input21
[    4.400703] input: Microsoft Surface Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input22
[    4.400808] input: Microsoft Surface Keyboard UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input23
[    4.400908] input: Microsoft Surface Keyboard Touchpad as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input24
[    4.401002] input: Microsoft Surface Keyboard UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input25
[    4.401095] input: Microsoft Surface Keyboard UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input26
[    4.401189] input: Microsoft Surface Keyboard UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input27
[    4.401274] input: Microsoft Surface Keyboard UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input28
[    4.401401] input: Microsoft Surface Keyboard UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input29
[    4.401501] input: Microsoft Surface Keyboard UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input30
[    4.401577] input: Microsoft Surface Keyboard UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input31
[    4.401649] input: Microsoft Surface Keyboard UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input32
[    4.401721] input: Microsoft Surface Keyboard UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input33
[    4.401795] input: Microsoft Surface Keyboard UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input34
[    4.401867] input: Microsoft Surface Keyboard UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input35
[    4.401939] input: Microsoft Surface Keyboard UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input36
[    4.402013] input: Microsoft Surface Keyboard UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07CD.0002/input/input37
[    4.402166] hid-multitouch 0003:045E:07CD.0002: input,hiddev0,hidraw0: USB HID v1.11 Keyboard [Microsoft Surface Keyboard] on usb-0000:00:14.0-1.4/input0
[    4.411533] mousedev: PS/2 mouse device common for all mice
[    4.453658] mwifiex_pcie 0000:02:00.0: info: MWIFIEX VERSION: mwifiex 1.0 (15.68.19.p21)
[    4.453665] mwifiex_pcie 0000:02:00.0: driver_version = mwifiex 1.0 (15.68.19.p21)
[    4.461144] mwifiex_pcie 0000:02:00.0 wlp2s0: renamed from mlan0
[    4.712672] Bluetooth: Core ver 2.22
[    4.712692] NET: Registered protocol family 31
[    4.712693] Bluetooth: HCI device and connection manager initialized
[    4.712696] Bluetooth: HCI socket layer initialized
[    4.712698] Bluetooth: L2CAP socket layer initialized
[    4.712702] Bluetooth: SCO socket layer initialized
[    4.721503] usbcore: registered new interface driver btusb
[    4.722091] Bluetooth: hci0: unexpected event for opcode 0x0000
[    4.724591] Bluetooth: hci0: unexpected event for opcode 0x0000
[    4.745074] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.745075] Bluetooth: BNEP filters: protocol multicast
[    4.745078] Bluetooth: BNEP socket layer initialized
[    4.989725] scsi 0:0:0:0: Direct-Access     Generic- SD Card          1.00 PQ: 0 ANSI: 6
[    6.335063] sd 0:0:0:0: [sda] 249737216 512-byte logical blocks: (128 GB/119 GiB)
[    6.335707] sd 0:0:0:0: [sda] Write Protect is off
[    6.335716] sd 0:0:0:0: [sda] Mode Sense: 2f 00 00 00
[    6.336389] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    6.344849]  sda: sda1 sda2
[    6.349174] sd 0:0:0:0: [sda] Attached SCSI removable disk
[   85.540346] Bluetooth: RFCOMM TTY layer initialized
[   85.540352] Bluetooth: RFCOMM socket layer initialized
[   85.540357] Bluetooth: RFCOMM ver 1.11
[   87.596951] mwifiex_pcie 0000:02:00.0: info: trying to associate to 'H3C' bssid 44:1a:fa:8c:2f:f2
[   87.782832] mwifiex_pcie 0000:02:00.0: info: associated to bssid 44:1a:fa:8c:2f:f2 successfully
[   88.006450] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[ 2525.497597] usb 1-1.1: USB disconnect, device number 3
[ 2525.497952] cdc_subset 1-1.1:1.1 enp0s20f0u1u1i1: unregister 'cdc_subset' usb-0000:00:14.0-1.1, Linux Device
[ 2578.069012] usb 1-1.1: new high-speed USB device number 6 using xhci_hcd
[ 2578.361988] usb 1-1.1: device descriptor read/64, error -71
[ 2578.549749] usb 1-1.1: New USB device found, idVendor=0525, idProduct=a4a2, bcdDevice= 4.19
[ 2578.549752] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2578.549754] usb 1-1.1: Product: RNDIS/Ethernet Gadget
[ 2578.549754] usb 1-1.1: Manufacturer: Linux 4.19.57+ with 20980000.usb
[ 2578.553239] cdc_subset: probe of 1-1.1:1.0 failed with error -22
[ 2578.554515] cdc_ether 1-1.1:1.0 usb0: register 'cdc_ether' at usb-0000:00:14.0-1.1, CDC Ethernet Device, 56:ac:15:42:d7:64
[ 2579.160703] cdc_ether 1-1.1:1.0 enp0s20f0u1u1: renamed from usb0
[ 2597.492626] IPv6: ADDRCONF(NETDEV_CHANGE): enp0s20f0u1u1: link becomes ready
[ 7214.577762] fuse init (API version 7.29)
lsusb
Bus 002 Device 004: ID 045e:090c Microsoft Corp. SD Card
Bus 002 Device 002: ID 045e:090b Microsoft Corp. Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 1286:204c Marvell Semiconductor, Inc.
Bus 001 Device 005: ID 045e:07cd Microsoft Corp. Surface Keyboard
Bus 001 Device 011: ID 0525:a4a2 Netchip Technology, Inc. Linux-USB Ethernet/RNDIS Gadget
Bus 001 Device 002: ID 045e:091a Microsoft Corp. Hub
1919715071
Re: Unable to pass RNDIS ssh [email protected]
Sat Jul 20, 2019 2:25 pm
IPv4 modified to only local connection
ifconfig
enp0s20f0u1u1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 169.254.190.137  netmask 255.255.0.0  broadcast 169.254.255.255
        inet6 fe80::587f:bac0:ca81:ef71  prefixlen 64  scopeid 0x20<link>
        ether 9a:78:54:4c:de:a9  txqueuelen 1000  (Ethernet)
        RX packets 42  bytes 9157 (8.9 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 141  bytes 15151 (14.7 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 322667  bytes 53181574 (50.7 MiB)
        TX packets 322667  bytes 53181574 (50.7 MiB)
wlp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.31.129  netmask 255.255.255.0  broadcast 192.168.31.255
        inet6 fe80::3718:ab9e:3a93:4be2  prefixlen 64  scopeid 0x20<link>
        ether bc:83:85:25:79:ea  txqueuelen 1000  (Ethernet)
        RX packets 39306  bytes 20332815 (19.3 MiB)
        RX errors 0  dropped 3558  overruns 0  frame 0
        TX packets 22722  bytes 6733515 (6.4 MiB)
ssh: connect to host 169.254.190.137 port 22: Connection refused
Return to “Arch”
