cjan
Problem - SSD failed, how to return to SD card?
Wed Apr 10, 2019 10:45 am
Rpi-2B, rootfs set to SSD and boot from SD-card.
now SSD went wrong, so how to back to SD-card without re-install?
after kernel huge updated, not match between / and /boot on SD.
Re: have a problem
Wed Apr 10, 2019 10:51 am
Can I suggest you change the topic title to something relevent to the problem? As its stands, very few people will bother looking at your problem. More detail in the question would also help.
cjan
Re: have a problem
Wed Apr 10, 2019 10:58 am
thanks, but can not figure out a topic title with my poor english :oops:
B.Goode
Re: have a problem
Wed Apr 10, 2019 11:05 am
Maybe most people will be unable to understand your question. For the same reason.
Is there a sub-forum here where you can post more clearly and fluently in your own language? viewforum.php?f=90
If a re-installation is necessary, perhaps now would be a good time to consider moving to the recommended and supported Raspbian Operating System.
Return to “Arch”
