How to login to Arch
Posted: Fri Oct 12, 2018 5:44 am
by Milliways
I decided to give Arch a try and after reading discouraging posts about Pi3B+ support from the Arch site, downloaded the following https://extonlinux.wordpress.com/2018/0 ... n-windows/
The site gave itself a glowing review, and I have flashed a SD Card. I had some initial misgivings (ttyAMA0 is assigned to console, despite being connected to Bluetooth).
I am now presented with a screen (in microscopic type) inviting me to login - I can find NO DOCUMENTATION and tried the usual suspects without success.
Any hints???
I tried root/root which works (why this was not linked to the page above is a mystery)
for some reason the the image had
framebuffer_width=1920
framebuffer_height=1080
commenting these out restored normal display.
Re: How to login to Arch
Posted: Fri Oct 12, 2018 7:47 am
by DirkS
IIRC in the past Arch used root / root as the default.
May be different for your image, though
Posted: Fri Oct 12, 2018 9:16 am
by B.Goode
To confirm, with documentation, what @DirkS suggests -
From http://raspex.exton.se/?p=859 (which you can find by using the Read More... link at the foot of the blog page you have cited) -
Login and passwords
Login as root with password root. Run the command startx to enter the LXDE Desktop.
Posted: Fri Oct 12, 2018 9:39 am
by Milliways
Login and passwords
Thanks. I did follow this link, but it was mainly a lot of waffle about Windows.
