ArchLinux Arm display unusual colors
Posted: Mon Jul 16, 2018 11:10 am
Hello all of you,
I have a Raspberry Pi 3 B+. With Raspbian the prompt, the directory and the files colors are correct at the console but with ArchLinux Arm at the beginning they where the same but now everything have a different color, even the Raspberry logo at boot up. These are the only personnalisation I do in the /boot/config.txt file
disable_overscan=1
framebuffer_height=1080
framebuffer_width=1920
In the /boot/cmdline.txt these are my kernel parameters
8250.nr_uarts=1 console=tty1 console=ttyAMA0,115200 dwc_otg.lpm_enable=0 elevator=noop fbcon=scrollback:2048k bcm2708_fb.fbswap=0 kgdboc=ttyAMA0,115200 loglevel=0 root=/dev/mmcblk0p3 rootwait rw smsc95xx.turbo_mode=1 usbcore.authorized_default=1 usbcore.autosuspend=-1 usbhid.mousepoll=0
Do you see something who can make this weird behavior?
disable_overscan=1
