Asus BT-400 Broadcom BCM20702A0 Bluetooth - Controller Not Found on Arch Linux ARM, kernel 4.14.32-1-ARCH
Posted: Sun Apr 08, 2018 5:49 pm
I have bluetooth dongle (Asus Bt-400 ) that I am using on a Raspberry Pi Model B (v1). I cannot seem to get bluetooth working. I am running kernel 4.14.32-1, with Arch Linux ARM installed. I am using Bluez 5.49. The bluetooth dongle is connected to a USB hub, LOGIK - L4THUB10. The details for the bluetooth usb dongle when I run lsusb is given as:
When I run the following bluetoothctl commands no controller is found.
I have to shutdown the raspberry pi, power off the usb usb, power on again and hope that the controller device is recognised by bluetoothctl. Sometimes this works, sometimes it doesn't.
I have tried the following:
1. Installed the firmware file, BCM20702A1-0b05-17cb.hcd, for the device, available from community Arch Packages. This is installed at /usr/lib/firmware/brcm.
2. Downloaded the Asus windows driver and inspected the inf file to identify the correct hex driver file for the device. Subsequently I used hex2hcd for my device and installed the firmware file (BCM20702A1-0b05-17cb.hcd) at /usr/lib/firmware/brcm
3. Built bluez-utils-compat 5.49-1 from Arch community repository to test with deprecated bluetooth toolset.
When I run I get the following dmesg output....
Sometimes I also get the following...
When I plug the bluetooth dongle into the usb hub, many instances of the message below is logged. This only happens when I plug the bluetooth dongle into the USB hub. The hub is running other USB devices. The message is not logged when I remove the bluetooth device from the hub.
I have also tried modifying the systemd bluetooth.service to be configured and run before the networking service as suggested at https://wiki.archlinux.org/index.php/Bl ... leshooting. Furthermore, if I run rfkill the device is listed as unblocked.
Modules listed by lsmod are included below:
There does not appear to be an individual usb device configuration for the bluetooth dongle, e.g.
Is this a bluetooth driver issue or an issue with usb hub driver?
Kind Regards
dcs3spp
Bus 001 Device 006: ID 0b05:17cb ASUSTek Computer, Inc. Broadcom BCM20702A0 Bluetooth
bluetoothctl
Agent registered
[bluetooth]# agent on
Agent is already registered
[bluetooth]# default-agent
Default agent request successful
[bluetooth]# list
[bluetooth]#
When I run
dmesg | egrep -i 'blue|firm'Code: Select all
[ 1.816784] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-03-16 16:17
[ 25.250290] Bluetooth: Core ver 2.22
[ 25.301799] Bluetooth: HCI device and connection manager initialized
[ 25.432350] Bluetooth: HCI socket layer initialized
[ 25.539945] Bluetooth: L2CAP socket layer initialized
[ 25.657534] Bluetooth: SCO socket layer initialized
[ 26.034466] Bluetooth: hci0: BCM: chip id 63
[ 26.138468] Bluetooth: hci0: BCM: features 0x07
[ 26.276530] Bluetooth: hci0: BCM20702A
[ 26.291533] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
[ 28.889841] Bluetooth: hci0 command 0xfc4c tx timeout
[ 36.230097] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 36.244019] Bluetooth: BNEP filters: protocol multicast
[ 36.470289] Bluetooth: BNEP socket layer initialized
[ 36.970529] Bluetooth: hci0: BCM: Patch command fc4c failed (-110)
[ 39.209790] Bluetooth: hci0 command 0x1001 tx timeout
[ 39.537967] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[ 39.844410] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.36
[ 47.209794] Bluetooth: hci0: BCM: Reading local version info failed (-110)
[ 1.816785] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-03-16 16:17
[ 25.002668] Bluetooth: Core ver 2.22
[ 25.066306] Bluetooth: HCI device and connection manager initialized
[ 25.189457] Bluetooth: HCI socket layer initialized
[ 25.289129] Bluetooth: L2CAP socket layer initialized
[ 25.397880] Bluetooth: SCO socket layer initialized
[ 25.793880] Bluetooth: hci0: BCM: chip id 63
[ 27.908806] Bluetooth: hci0 command 0xfc6e tx timeout
[ 35.353127] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 35.353140] Bluetooth: BNEP filters: protocol multicast
[ 35.353177] Bluetooth: BNEP socket layer initialized
[ 36.329932] Bluetooth: hci0: BCM: Read controller features failed (-110)
[ 37.389283] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[ 37.453147] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.36
WARN::dwc_otg_handle_mode_mismatch_intr:68: Mode Mismatch Interrupt: currently in Host mode
sudo rfkill list
[sudo] password for alarm:
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
Upon inspecting the code for the [btusb](https://github.com/raspberrypi/linux/bl ... th/btusb.c) driver I notice the following at lines 156-158:Module Size Used by
ccm 20480 3
bnep 20480 2
arc4 16384 2
rt2800usb 28672 0
rt2800lib 110592 1 rt2800usb
rt2x00usb 20480 1 rt2800usb
rt2x00lib 53248 3 rt2800lib,rt2800usb,rt2x00usb
mac80211 647168 3 rt2800lib,rt2x00lib,rt2x00usb
btusb 40960 0
btrtl 16384 1 btusb
btbcm 16384 1 btusb
btintel 16384 1 btusb
cfg80211 577536 2 rt2x00lib,mac80211
bluetooth 356352 12 btrtl,btintel,bnep,btbcm,btusb
crc_ccitt 16384 1 rt2800lib
ecdh_generic 28672 1 bluetooth
bcm2835_rng 16384 0
rng_core 16384 1 bcm2835_rng
uio_pdrv_genirq 16384 0
fixed 16384 0
uio 16384 1 uio_pdrv_genirq
sch_fq_codel 20480 5
snd_bcm2835 32768 0
snd_pcm 94208 1 snd_bcm2835
snd_timer 32768 1 snd_pcm
snd 65536 3 snd_timer,snd_bcm2835,snd_pcm
crypto_user 16384 0
ip_tables 24576 0
x_tables 24576 1 ip_tables
ipv6 434176 40
/* ASUSTek Computer - Broadcom based */
{ USB_VENDOR_AND_INTERFACE_INFO(0x0b05, 0xff, 0x01, 0x01),
.driver_info = BTUSB_BCM_PATCHRAM },
{ USB_DEVICE(0x0b05, 0x17cb) }Kind Regards
dcs3spp
