Havinit
[solved]RPi 3B+ Wifi
Sat Mar 17, 2018 5:49 pm
Just got my 3B+ yesterday and have loaded it up with latest Archlinux-ARM tarball. The onboard wifi device is not detected (although the Bluetooth on the same chip is). No sign of a wlan0 in e.g. iw list or rfkill list.
I assume this is because the newer kernel+firmware that Raspbian had ready to go before launch-day has not been packaged for Archlinux-ARM yet, so it is now just a waiting game?
Just want to be sure that's the issue and not that I'm failing to do some configuration step or whatnot. I skipped over the Pi3 so I'm a newbie to the onboard wifi world.
Thanks in advance if anyone can set this niggling doubt to rest for me, while I sit obsessively hammering pacman -Syu ;)
Re: RPi 3B+ Wifi
Sat Mar 17, 2018 6:39 pm
You will need to contact the ARCH Linux Arm Developers / Community as they are solely responsible for supporting their software:
https://archlinuxarm.org/forum/
The Raspberry Pi Foundations Raspbian Stretch latest release does obviously work..
gkaiseril
Re: RPi 3B+ Wifi
Sat Mar 17, 2018 6:54 pm
A quick check of the release notes for the 2018-03-13 image states:
2018-03-13:
* Raspberry Pi 3 B+ support
* WiFi is disabled until wireless regulatory domain is set (Pi 3 B+ only)
- The domain can be done through 'Raspberry Pi Configuration' (rc_gui),
'raspi-config' or by setting 'country=' to an appropriate ISO 3166
alpha2 country code in /etc/wpa_supplicant/wpa_supplicant.conf.
* Default wireless regulatory domain is now unset
You need to make sure you have set the appropriate country code by any of the possible ways to change the Pi's configuration.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
Re: RPi 3B+ Wifi
Sat Mar 17, 2018 7:00 pm
2018-03-13:
How is this related to ArchLinuxArm :roll:
Havinit
Re: RPi 3B+ Wifi
Sat Mar 17, 2018 8:04 pm
Thanks for the replies.
@fruitoftheloom: I do realise that only Raspbian is the "anointed" distro, and I'll certainly join and post on archlinuxarm forum in a few days if an update hasn't resolved it by then (which is what I'm anticipating will happen). But I'm already a member here so I thought I'd see if any other Arch users on here already knew the score. There must be some reason for this subforum to exist, no?
@gkaiseril: I think the disabling unless country-code is set is a Raspbian-specific tweak; apparently it was introduced in the same Raspbian image (13/03/2018) that has the new firmware. I didn't see any suggestion in the threads I've read that it's a feature of the new hardware itself but perhaps I'm wrong. In any case the people having issues with that do actually have a wlan0 device showing up, which Arch doesn't, hence my assumption that it just doesn't have the necessary driver/firmware yet.
cjan
Re: RPi 3B+ Wifi
Sat Mar 17, 2018 10:48 pm
latest Archlinux-ARM tarball installed then update to last Linux alarmpi 4.14.27-1-ARCH #1 SMP.
Havinit
Re: RPi 3B+ Wifi
Sun Mar 18, 2018 12:49 am
@cjan: Are you saying that that kernel has the required update? I updated to that last night but it has not changed the situation.
This is all there is in dmesg from brcmfmac:
[[email protected] ~]# dmesg|grep brcmfmac
[    7.848567] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43455-sdio.bin for chip 0x004345(17221) rev 0x000006
[    7.850795] usbcore: registered new interface driver brcmfmac
[    7.986350] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.txt failed with error -2
[   11.007447] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[   12.017191] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
cjan
Re: RPi 3B+ Wifi
Sun Mar 18, 2018 1:06 am
sorry can not help, don't have 3b+.
last kernel and firmware just for new 3b+.
cjan
Re: RPi 3B+ Wifi
Sun Mar 18, 2018 6:23 am
seems miss 2 files in /lib/firmware/brcm
*brcmfmac43455-sdio.clm_blob
*brcmfmac43455-sdio.txt
cjan
Re: RPi 3B+ Wifi
Sun Mar 18, 2018 7:46 am
btw, firmware-raspberrypi got update an hour ago.
Havinit
Re: RPi 3B+ Wifi
Sun Mar 18, 2018 9:22 am
Excellent, just updated and all is good. Thanks for the tipoff :)
SA7SKY
Contact: Website Skype
Re: [solved]RPi 3B+ Wifi
Sun Mar 18, 2018 1:36 pm
Are firmware-updates delayed on its way to Europe.
I did the whole procedure a minute ago but still no change on the version:
4.14.27-v7+ #1100 SMP FRI MAR 16
Besides that: same problem, no wlan0 detected.
Any hint?
//Helge
Havinit
Sun Mar 18, 2018 6:27 pm
@SA7SKY, when you say you did the whole process, do you mean prepared a new SD card from a freshly-downloaded tarball?
Have you also updated by running "pacman -Syu" (as root)?
manawyrm
Mon Mar 19, 2018 10:41 am
Just FYI if you encounter something like that again:
http://www-numi.fnal.gov/offline_softwa ... rrors.html
Error code -2 is ENOENT - /* No such file or directory */.
That can give you the required hint, that you're missing a firmware file.
Especially happens with propritary HW like TV tuner cards or enterprise network cards, that need FW blobs to work correctly.
Have fun,
Tobi
Return to “Arch”
