Occasionally (maybe 1 out of 10 times), when I reboot my RPi3, I get a kernel panic. It can be fixed by power cycling, but the root cause of the problem is what I would like to identify. Unfortunately, systemd does not write anything to the log/it's as if the boot up never happened. I am only able to capture what I see in a pic and unfortunately, it's not all of the kernel panic. I did find
this thread in which some are thinking the micro SD might be to blame but in my case, the system functions totally fine when it does boot, and the panics are sporadic in nature.
Thanks for any insights.
Hardware: Raspberry Pi 3.
OS: Arch ARM running ARMv7h (not the 64-bit aarch64 kernel).
Link to pic of partial output in the panic state:
