nikolaevican
Arch Linux 32 bit
Thu Oct 12, 2017 9:21 am
I have rpi3 and lookup 32 bit linux image that supports systemd.
I decided try Arch, but on https://archlinuxarm.org I found only 64 bit.
Can anybody tell where I may download 32 bit image?
Re: Arch Linux 32 bit
Thu Oct 12, 2017 9:23 am
Raspbian uses systemd, that would be the best 32bit OS.
Please direct all questions to the forum, I do not do support via PM.
cjan
Thu Oct 12, 2017 10:24 am
A bit off topic.
procount
Thu Oct 12, 2017 10:38 am
PINN will download & install Arch 32-bit for you.
nikolaevican
Thu Oct 12, 2017 12:23 pm
Raspberian kernel doesnt support cpuset cgroup. I think therefore, when I change rootfs to own, I receive error -
Failed to mount cgroup at /sys/fs/cgroups/systemd: No such file or directory[!!!!!!] Failed to mount API filesystems, frezing.
Koeshi
Mon Oct 16, 2017 11:27 am
If you follow the ARMv7 Installation instructions from this page you will get the 32-bit version: https://archlinuxarm.org/platforms/armv ... berry-pi-3
Return to “Arch”
Who is online
Users browsing this forum: No registered users and 1 guest
